Double pulsatory solution\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
Started by iacob alex, April 27, 2007, 04:37:11 PM
iacob alex
...can be a proposal for a self moving configuration under the influence of gravity,only.
The first pulsatory motion,is made by the mobile mass in a flapping or flip/flop solution,nothing new...
The second pulsatory motion is that of the axis,inside the fulcrum,so that to have contact/support point/line of the axis and the two centers of weight/of the arms on the same straight line for two identical but opposite positions.
So,to be short,if we add and relate an inner pulsatory motion/that of axis face to fulcrum ,with an outer pulsatory motion/flapping,flip flop...it can be an open way for new experiments.
                All the  Bests!  /  Alex
FreeEnergy
post a picture relating to what you just described above . or post url link directly to the picture you just described above. thanks :)
peace
iacob alex
  The shape of an idea can be so different...so,I believe that my fresh design/...I will post it in the future.../  can be more useful as a general description.
It can be a way,to develop as in any oscillatory interplay,a mutual relation between two partners that shares the same game.
This time,the game is connecting in the same space gravity and rotational inertia.
If you make a lot of tests ,with some flapping/flip flop designs it is easy to notice,that the fulcrum/bearing is not responding  or is like dead.
That designs you can find easy,if you type on net the word  Stellarotor.
The next proposed step,can be to relate the flapping motion of the variable arm with a tumbling motion of the axis in the fulcrum,in some way...yours alltime is better than mine.
To be short,if we are flapping gravity,we need a similar echo,a reflection of this motion from the turning axle in the bearing/fulcrum,a kind of tumbling,eccentric process.
iacob alex
  ...you can find at    www.geocities.com/iacob_alex    ,then click on "Some_Drafts/text008.jpg  ,with the title "Flapping Double Swing".
iacob alex
.....playing double leverage and inclined plane , so to maintain a continuous gravity unbalance , on the same side of fulcrum , at:
    www.geocities.ws/iacob_alex/Some_Drafts/text008.jpg
    With  a single variable arm , take a look at :
    www.geocities.ws/iacob_alex/Some_Drafts/text028.JPG
    Al_ex
