Nu Energy Source Discovered through an Alpha Fusion Reaction
Started by Bruce A. Perreault, May 04, 2007, 09:38:45 PM
Bruce A. Perreault
Attention!
The ball has been dropped please do your part. Get this disclosure out far and wide as fast as you can! I will not be available for comment on this technology until it is in production. Please discuss the contents with other members. I am extremely busy and I am usually running around with my head cut off from the rest of my body. It will be too hard to focus on what I need to do if I have to answers thousands of questions and be on the phone for hours. My business phone will be disconnected for a few days until the dust settles a little.
                       -Best Regards, Bruce P.
http://www.nuenergy.org/disclosures/Perreault-Nu-Energy-Patent-Disclosure-1.pdf
The Password: Zeta159Nu756678
http://www.nuenergy.org/disclosures/Perreault-Alpha-Fusion-Patent-Disclosure-revision_05-04-2007.pdf
This is the revised disclosure that will be submitted the United States Patent Office later tonight.
pese
Ros-Co.
Dear Bruce!
I found a new document on your page.  Maybe it's the key to reproduce Moray's device.
Now, I think the energy only just produced by plasma discharge, or mechanical oscillation in the transformer's core material.
My college show me a document about Paul Brown's experiments.  I think the effect is similar to the Moray's tube.
The atomic batteries dicovered very early, but is produces high voltage, and very low current. Siply just capture the beta ray's electrons.
Paul Brown (and Moray?)  discover the "multiplicating"  effect during de decceleration of alpha particles, in the metal surface.  The efficiency depends on the metal type. Example Ag is very preferred.
This effect produces current in the conductor.  Moray and P. Brown place this device into a resonant circuit. If I think that correctly, the electric field of the capture coil (or electrode)  modulating the emission of the radioactive particles, and produces high frequency currents in the coil.
I have an idea, that what is the common effect in the OU devices (like Hendershot, Bedini, Moray, E.Gray, etc. devices)  The common characteristic is the  accelerating of
charges, capture energy from the field, and charge the battery, or other.
the accumulators of Bedini  stops the energy flow.  The electrolit capacitors too.  (Hendershot use electrolitic film in his device)  Maybe the plasma is the perfect for capture this enegy?
Could you tell me wat types of material used in the tube, that easy to obtain. Special materials (like Bizmut, Molibden) is a little bit difficult to buy...
sorry for my bad english..
Regards:
Ros-Co.
DavidE
Hey Bruce... still packaging your OU generators with explosive protective devices?
pix
