Interesting experiment with Meyer's type cell.
Started by Bruce_TPU, May 05, 2007, 01:55:56 PM
Bruce_TPU
My true interest is HHO.  I am working on SM's TPU, because my HHO cells need more power.
While working on Sound frequency today on the TPU, I decided to drop a mini underwater speaker into my experimental rig with a Myers type cell.  (6" in length, ss 3/8" center tube with ss 1/2" outer pipe.
At 20K hz sound (as high as my sound card gets) there was a DEFINITE increase in gas production.  This increase was visible and noticable.  I did this many many times to verify.
When I get a real sound freq. generator in about two weeks, I will continue experimenting along these lines, along with the TPU.  I want to amplify the sound through a tube circuit and into a mini underwater speaker and play with differant High frequencies.  I wanted to tell you guys about this, because I think there is some potential here.  I have not tried it on plate cells as of yet.
Thank you for your time,
Bruce
Paul-R
John Worrell Keely reckoned on 42.8 Mhz as a crucial
frequency. Miles out of the range of a sound card,
obviously. But there will be an octave lower down that
will be worth trying, to be found by halving the frequency
repeatedly:
http://peswiki.com/index.php/PowerPedia:John_Keely
Are you sure that you are not simply shaking the bubbles
off the plates?
Paul.
pese
Quote from: Paul-R on May 06, 2007, 09:49:37 AM
repeatedly:
off the plates?
Paul.
Give attention on the frequency !!
Peswiki say:
Exploding water with 42712.2Hz
This are : 42,72122 Khz   !!!
You can (double? or) triple the frequnzy from soundcard
PESE
Bruce_TPU
off the plates?
Paul.
Great info about Keely!  Thank you.  I am not sure if it is vibrating the bubbles off the tube capacitor (no plates) or not.  Even if it is, it still furthers production somewhat.  BUT none of the bubbles on the outside of the outer stainless pipe (1/2 stainless 6" nipple) moved.  Wouldn't it be amazing if sound could be used to further weaken the convalent bond of the water, thus allow for greater production with the same amount of electricity?  Just thinking aloud.
pese,
How can I double or triple my laptops sound card frequency range?  This would be VERY helpful for all of my experiment.  Thank you in advance pese!   :D
pese
http://www.tpub.com/content/neets/14181/css/14181_95.htm  HERE
http://www.tpub.com/content/neets/14181/css/14181_65.htm   Overview  = Oscillator
www.stormloader.com/members/pese/liLIST.html   click to science
G Pes?
Give attention 42 Khz  not Mhz !!!
Very big Difference
