New accelerating gravity wheel ! Converted video from www.newenergymachine.com !
Started by hartiberlin, May 11, 2007, 12:49:03 AM
hartiberlin
Hi Mikey,
many thanks for posting this article link !
I am just copying here now all the text files and the
pictures, cause Bob?s last site was deleted,
so we have it at least here to stay for protection !
I think this is the breakthrough we all have been waiting for and
Bob is the new Bessler of 2007 !
Here it is copied from:
http://www.thepost.ca/webapp/sitepages/content.asp?contentid=679901&catname=Local%20News&classif=News%20Live
Little Britain man turning gravity into power
'You can get off the grid with one of these': inventor
Jason Bain
Local News - Tuesday, September 04, 2007 Updated @ 4:44:19 PM
LINDSAY ? When he heard on television that gravity couldn't be used as a form of energy, Bob Kostoff set out to prove Discovery Channel wrong.
?I said, 'That doesn't make any sense,'? said the Little Britain resident, using dropping a cement brick from a standing height as an example.
If you were to place your hands a few centimeters off of the ground to try to stop it before it hits the ground, you wouldn't be able to because of the energy powering the bricks fall, he said last Friday.
With that concept in mind, Kostoff sought to make a 'perpetual motion machine' that could offer a clean, alternative source of power using gravity as 'fuel.'
After about four years of planning and development through trial and error ? including about a year-and-a-half creating the designs on paper - Kostoff reached his goal.
He now owns the patent on the technology to prove it.
The result was 'The Gravity Powered Machine.' The self-sustaining engine provides as little as 10 foot-pounds of torque or as much as hundreds, Kostoff said, adding how its cost is less than half of a small wind turbine.
The machine ? which only requires a little bit of start-up juice before it creates enough power to sustain itself - works much like a teeter-totter, using a series of sliding weights that, with the help of the earths gravitational pull, force the unit to continue spinning around in a circle.
Install a series of magnets in the unit and tens of thousands of watts of electricity can be produced, an amount that depends on the size of the actual machine.
?You can get off the hydro grid with one of these,? Kostoff told The Lindsay Post.
So far, about five of the units have been made. Once he got the concept down, he said he began fine-tuning the more cosmetic aspects of the machine, such as reducing noise.
?Once you figure it out, it's just about perfecting it,? he said.
A former employee of Matthews Conveyor who also ran his own computer stores in Lindsay and Port Perry, Kostoff hopes his new invention will eliminate the need for fossil fuels.
The machines can be used in a variety of applications, Kostoff said, because they produce electricity at no cost.
For example, he said the units can be used to generate the power needed for electrolysis, a process that creates hydrogen, a ?free fuel? that could be used to power your personal vehicle.
For more information on the gravity powered engine, or to see a video of it in action, visit www.newsourceofenergy.com
NEW SOURCE of ENERGY
Gravity Powered Engine
? New source of energy
? Powered by gravity
? Needs no fuel to run
Introduction
This engine is a self sustaining gravity powered unit. It produces all the
energy needed to run a generator large enough to provide power for
all the hydro and heat needed for your home. This patented system
can be as small as producing 10 foot pounds of torque or as much as
over 300 foot pounds of torque.
Each unit is approximately 8 feet by 4 feet by 6 feet tall and is totally
enclosed for safely protection against moving parts.
This new engine is the product of years of research, frustration and
perseverance. I found that using the perpetual motion approach limits
the amount of usable energy available. An internal combustion engine
can be enhanced and will produce more power by installing a turbo
charger. This unit will use some of the initial power produced by the
engine, but the end result is far greater. The same process is used
in this unit but because it uses Gravity rather than fuel, the enhancement
system is much different.
The new design changes to the machine and improvements to the
enhancement mechanism look very promising and should deliver
over 500 foot pounds of torque.
This web site is not here to sell anything. It is only to inform you that
a new source of power will soon be available.
The cost of the unit will be surprisingly inexpensive.
Newer Machine Specs.
Length    approximately 8 feet
Width    approximately 4 feet
Height    approximately 6 feet
weight     450 lbs
Torque    over 100 foot lbs and up
Read me first
Video is available of older machine to view newer machine soon to be posted
This is an older model machine that delivers approximately 1 to 1 1/2 horse power. This was the first test of this machine and was not fully balanced.
Procedure
First I have to loosen off the disk brake until it has a small amount of resistance, then give the machine a little push. As it starts to rotate and picks up speed I tighten the brake just enough to control the rotation speed. This is normally handled by a governor on the newer machines. The machine must rotate at a pacific speed to keep the generator constant. To stop the machine I just tighten the crank on the disk brake assembly and it works the same way as the disk brakes work on a car.
Okay, here are all the pictures I have found about this machine  attached to this
posting:
hartiberlin
The last picture file94200744448PM.jpg had a subtitle:
Little Britain resident Bob Kostoff controls an early version of 'The Gravity Powered Machine' as it turns at a high rate of speed. The machine, which he has patented, generates power using gravity.
Here are attached the 2 videos I found on his website:
hartiberlin
Here is the Canadian patent office website,
but I did not yet find any gravity related patent by the inventor name
Kostoff, so maybe someone else is lucky to find it ?
http://patents1.ic.gc.ca/srch_adv-e.html
Many thanks.
Regards, Stefan.
TheOne
the only thing i see related to gravity and recent are this patent
http://patents1.ic.gc.ca/details?patent_number=2497861&language=EN
but its from LAROCQUE, LEONARD but the patent is not avaialble for download yet
Filled in 2006
Prophmaji
I live about 2 hours from Bob. Maybe I can do a quick look-see as to what is going on. I'd certianly like to take a look at it.
I suspect the patent has been 'approved' but not fully cleared of the Canadian Patent System, and Bob may now be applying for US protection as well.
