New accelerating gravity wheel ! Converted video from www.newenergymachine.com !
Started by hartiberlin, May 11, 2007, 12:49:03 AM
hartiberlin
Bob is probably converting the centrifugal forces into useful forces
over here.
If the upper shifting weight at 12 o?clock hits the upper end of the 12 o?clock  arm,
this hit pulse can be transfered via airpressure down to the lower weight
hiting there a spring and pushing the lower weight at 6 o?clock into the direction
of the axis !
So the centrifugal force of the upper weight hitting at 12 o?clock
helps to pull up the weight at 6 o?clock.
This is a pretty amazing principle, which has not until now being used.
As centrifugal forces can get very big in such a system, the output power
can get very high !
Very clever Bob !
Regards, Stefan.
tao
Quote from: hartiberlin on September 09, 2007, 11:10:25 AM
over here.
of the axis !
can get very high !
Very clever Bob !
Regards, Stefan.
Air pressure as a centrifugal energy conversion device, can't wait to hear more.
All signs point to this being a 100% authentic device, again, can't wait to hear more.
hartiberlin
Hi Tao and all,
the principle of this device is pretty simple.
I have understood it by now.
You can try it yourself very easily.
Just take 2 x 5 Liter  buckets filled with water.
One in each hand.
Now pull your hands 180 degrees apart and rotate the 2 water
buckets in a vertical plane.
See, how strong the centrifugal forces are and so the water
stays in the buckets and will not spread onto your head ! ;)
Now now retrieve one bucket , so that you hold it with a tightened
muscles, so it stays a bit less way from the center of rotation.
Now let this retrieved weight bang at 12 o?clock against a "mysterious"
wall, which transfers the bang energy to the nonretrieved full arm long bucket
at 6 o?clock.
This will make the 6 o?clock bucket jump into the direction of the center
of rotation.
The 12 o?clock bucket still stays full long arm out until it itself reaches 6 o?clock,
where the other retrieved bucket is again loosened at it hits also the
12 o?clock  "mysterious" wall, so the energy is again transfered down to the
other bucket at
6 o?clock , which will be retrieved then again into the direction of the center
and fixed their, until it is again let go at shortly before 12 o?clock.
So the lever arm from 12 o?clock to 6 o?clock will always be heavier
and the resetting is done via the immense centrifugal "fictitious force",
which is thus converted into a real force doing work !
Regards, Stefan.
tao
Quote from: hartiberlin on September 09, 2007, 07:57:54 PM
Hi Tao and all,
One in each hand.
at 6 o?clock.
of rotation.
other bucket at
Regards, Stefan.
Plus, since the other weights on the left side of the wheel are 'locked' into position nearest the shaft, and since there is a weight difference on the right side of the wheel, that could easily be ADDED to the centrifugal energy conversion...
So, if converting the centrifugal force from the 12 o'clock weight wasn't enough, you still have all that gravitationally imposed energy from that left-side / right-side differential to use to aid in lifting that 6 o'clock weight.
This is a VERY impressive device so far, waiting to see what Bob does next..............
tao
