New accelerating gravity wheel ! Converted video from www.newenergymachine.com !
Started by hartiberlin, May 11, 2007, 12:49:03 AM
LarryC
Quote from: AB Hammer on August 24, 2008, 12:19:15 PM
@LarryC
I looked at what you have done. The arm impact to make the shift will cause you a severe shake/jar and tear it apart even if you get it running, it won't run long. I have already played with this concept last year with counter weights and I understand the jarring that you are going to be effected with plus the CF problem. If you have any questions pleas ask in an email due to over exposure. ab.hammer@yahoo.com
Thanks Ab, for the confirmation.
Did realize that after I digested the warping problem. Along with the heavier hardware, I have also designed a gradient cam guide that will start off gradually and increase the rise rate as it approaches midpoint + 1". Much more tweaking!
Regards,Larry
AB Hammer
LarryC
You are going to need much better construction as well. Try screen door roller bearings and 1/4 inch round stock steel for your track, and stronger bolts like carage bolts ect.
Good luck, you are getting close. P.S. you do know what my statement means?
Alan
LarryC
Quote from: AB Hammer on August 24, 2008, 01:26:42 PM
LarryC
You must have missed my previous post, had picked up sliding glass door roller bearings and 1/2 " angle iron for track.
Regards, Larry
AB Hammer
OOPs post #357 LOL
I prefer round bar stock the rollers with the 1/2 round track fit them perfectly. less friction.
Alan
I really want to help out with some wm2d sims but I don't understand the design. NS's drawings don't make much sense to me.
