New accelerating gravity wheel ! Converted video from www.newenergymachine.com !
Started by hartiberlin, May 11, 2007, 12:49:03 AM
I believe then mine and maybe even Larry's weight are going way to far. Maybe the offset shouldn't be that big...will experiment with this.
noonespecial
Quote from: LarryC on August 27, 2008, 06:30:59 PM
@Charlie,
Very interesting that Bob stated the shock type bellows latched the weights. Tried to look for it in his pic, but having a hard time finding any clue. Any insight!
Sorry, no. I went back and tried to step through the video again frame by frame but the frame rate is low that everything is just blurred as you know.
Short of having Bob come back and tell us how he's doing it, I'm afraid we are left to speculate and experiment until we discover something......
Regards,
Charlie
noonespecial
@Charlie,
Regards,
Charlie
[Edit] Sorry for the double post...having a hard time lately accessing the forum again..... ???
LarryC
Quote from: broli on August 28, 2008, 05:59:40 AM
Hi Broli,
I tried to check out your statement by analyzing the Bob machine pic in reply #286.
Bob's shoe size seems to be around a 9, really sorry Bob to get personnel but your disappearance leaves us no choice.
Considering that shoe size, then the plate weights seem to be a 10" x 14" rectangle. In the pic a semi V support structure seems to be holding the center of the unit. The upper weight plate held by the bellow shock seems to be 5 to 6" from the center of the unit. If the plates are moving 24" then you should be able to use this info for the offset. My original version seems to be close.
Regards, Larry
noonespecial
@All
OK...here's my take on the air cylinder(s). I tried to catch a screen shot of what I believe is the air cylinder that he is using. There are other objects to the immediate right that look similar but I don't know what they are. Bob does mention that he uses 3 techniques to raise the weights..air cylinder, cam and actuator arm. I don't think this will work without all 3. Let me know what you think.
Regards,
Charlie
