New accelerating gravity wheel ! Converted video from www.newenergymachine.com !
Started by hartiberlin, May 11, 2007, 12:49:03 AM
noonespecial
Hmmm. I just noticed what looks like the bottom air cylinder just below the top of the table in the foreground. So perhaps my drawing is pretty close to what he is doing.......
Charlie
AB Hammer
Greetings Charlie and Larry C
Send me an email to ab.hammer@yahoo.com, and I will send you a confidential video. I don't want this video to be published, but it might give you some help on your project. It is one of my almost runners and it has a similar problem of what you have been facing. Then we can talk on the forum, I just don't want to show the video or any drawing of it.
Alan
LarryC
Quote from: noonespecial on August 29, 2008, 09:52:32 AM
OK...here's my take on the air cylinder(s). I tried to catch a screen shot of what I believe is the air cylinder that he is using. There are other objects to the immediate right that look similar but I don't know what they are. Bob does mention that he uses 3 techniques to raise the weights..air cylinder, cam and actuator arm. I don't think this will work without all 3. Let me know what you think.
Yes, Charlie your air cylinder accumulator theory does sound very feasible. Still it dishearthen me a little as I find it would be expensive to duplicate.
But, my guess in your 3 ? in the vid pic seems to be the springs uncompressed in the top line off the 3 ?, and the top end  of the weights in the bottom line off the 3 ?.
BTW, I have new slender weights boxes built which weight 2.5 lbs with the patio door rollers installed. But weights can be added to it from 1 to 12 lbs in each box. Picture it more like a double axe blade without the flair. I have the 24" roller guides cut and pre-drilled to be attached to the supporting arm.
I spent my spare time today putting up hurricane shutters as I am in SE La. and waiting for Gus.
Hopefully it turns away and I can get out tommorrow to pick up the parts for the main arm.
Regards, Larry
noonespecial
Quote from: LarryC on August 29, 2008, 06:47:19 PM
Yes....makes perfect sense.
QuoteBTW, I have new slender weights boxes built which weight 2.5 lbs with the patio door rollers installed. But weights can be added to it from 1 to 12 lbs in each box. Picture it more like a double axe blade without the flair. I have the 24" roller guides cut and pre-drilled to be attached to the supporting arm.
Are going to be using your new design with gradual return curve?
QuoteI spent my spare time today putting up hurricane shutters as I am in SE La. and waiting for Gus.
Stay safe my friend. I hope it changes direction for your sake as well. Talk to you soon....
Charlie
4Tesla
Hi Larry,
Yes, be safe with the hurricane.. hope it misses your place!
Jason
