New accelerating gravity wheel ! Converted video from www.newenergymachine.com !
Started by hartiberlin, May 11, 2007, 12:49:03 AM
AB Hammer
Alan
squegee69
Quote from: noonespecial on August 29, 2008, 10:08:10 AM
Hmmm. I just noticed what looks like the bottom air cylinder just below the top of the table in the foreground. So perhaps my drawing is pretty close to what he is doing.......
Charlie
You guys are probably on the right track.  Looks like a lot of pneumatic equipment laying around Bob's workshop.  Also could be an air shock modified to act like a piston.
Peace all.
Arbeit macht frei
LarryC
Thanks,
Charlie and Jason for the well wishes, but I just hope these storms would just go back to normal size before global warming occurred. After getting wacked badly and surviving Katrina, that is my main reason for being here.
@Charlie,
Are going to be using your new design with gradual return curve?
Yes, that will be my first shot, but with the new weight box/patio roller slide design I'll be able to have the cam at the outside or the center, or any combination of cam/inside/outside plus lever.
Still hoping Broli can reduce the tweaking time!
Regards,
Larry
noonespecial
Quote from: AB Hammer on August 29, 2008, 10:01:29 PM
OK guys Videos sent.
Thanks AB. However, it would have been more helpful if you showed it stopped and then starting.
I'm also a little confused about how you want to proceed. If you want your design to remain proprietary, how do we discuss it here in an open forum?
Regards,
Charlie
AB Hammer
Greetings Charlie
I just got off the phone with Larry C. It is looking like he may have to go to higher ground.
In the video I sent you, I am wanting you to look at the springs. They tended to make the wheel flywheel neutralizing the slide. They will work against what you are trying to do, but lighter springs will help smooth off the vibration and jarring you are going to have. I will be finishing a newer version of that wheel with a new arrangement,  That is the reason I didn't want it shown. I have 2 others to finish first.
Alan
