New accelerating gravity wheel ! Converted video from www.newenergymachine.com !
Started by hartiberlin, May 11, 2007, 12:49:03 AM
noonespecial
@All,
Bob's comments on how the levers work:
"The way to lift the weight to the opposit end is at the 4:00 oclock position an  arm from the centre, on a cam mecanisum to the end of the arm (2.5 ft) is forced around and lifts the linked weights 1" farther than 1/2 the total travel. Centricical force will lift it the rest of the way. It acts like a leaver 2.5" to centre and 10" past.The farther it pushes the weight from the bottom the easier it gets.The first 2" is the heaviest. The spring mecanisum helps at the first of the upward stroke.
A cam mechanism picks up the weight in the center of the wheel and raises them up approximately 4". After the cam, the actuator arm brings it the rest of the way. (8"). "
Based on those comments, LarryC and I have developed a similar weight lifting lever system which can be hidden behind the rotor portion of Bob's unit. You have probably noticed that there are no photos of the back of the machine. The weight and springs in our picture are just shown for clarity, they are actually on the other side in Bob's unit.
Larry is currently working on detailed dimensions and will post them in a day or two.
Regards,
Charlie
valveman
Emailed Bob and no response.  Guess he's not interested in anyone seeing his machine.
Robert
valveman
@ noonespecial
I like the diagram and followed the explaination.  Wasn't it also mentioned that a weight was placed on the lever?  When the actuator takes the weight the rest of the way, how does it get recharged to do this all over again?
Yes there is a pic of the rear of the machine.  I still see no indication of a lever.
Robert
LarryC
@all,
The following drawing has more detail dimensions on the hidden weight lifting system shown in Charlie's last drawings.
Regards, Larry
noonespecial
For those who can't open a .doc here's a jpg version of Larry's detail.
Regards,
Charlie
@Valveman
I don't think that Bob was referring to a literal weight but rather the force applied to the lever to lift the weights up.
Regarding the drawing, the weight will ascend to the top by centifugal force as the rotation continues and lock into the upper weight slot to be lifted again at the bottom of the rotation.
RE: pic
This is still the front side of his machine. The large pulley drives the 5K generator at the bottom.
