New accelerating gravity wheel ! Converted video from www.newenergymachine.com !
Started by hartiberlin, May 11, 2007, 12:49:03 AM
unity2zero
In 1712, if only Johann Bessler would simply let out his secret of his perpetual gravity wheel to the world before he died, those ice in the north pole shouldn't be melting or at least very much later. The air we breath now should be so much purer. No flooding of rivers to make hydro electric. Imagine thousands upon thousands of animals, birds and species including plants, trees and forest were being wiped by building these dams.. Sigh !!
LarryC
Quote from: unity2zero on September 25, 2008, 11:21:30 AM
Unity2zero,
Well stated, now are we going to let it happen again?
@All,
Recheck reply #105 by hartiberlin. The newspaper is The Lindsay Post of Ontario,Canada by Jason Bain. He is still posting at that paper so seems to still be credible.
If Bob was running his machine from an outside energy source a decent reporter would have ate him up!
Recently, there seems to be a lot of concern about other equipment laying around in his shop. Just think if every piece of old equipment in your shop was though to be part of your energy machine.
I don't know about Bob's condition after his serious auto accident and rehabilitation, so lets at least give him the benefit of the doubt.
So can anyone else try to help figure out how to get Bob's machine replicated instead of why it can't work?
Regards, Larry
Pirate88179
Larry:
With all due respect, any comments I made were not about "other equipment laying around his shop", as you put it.  My comments were directed toward the "other equipment" that was ATTACHED to his device.  (see previously posted photo enlargement.)  Just follow the hoses, it is easy to do.
I was then told that this photo was not THE machine but a previous model.  OK.  I said I don't know anything about that.  I was not aware there were multiple machines we were dealing with, and if I made that mistake, it is my fault.
But, to say that were are confusing stuff laying about his shop with his machine is very disingenuous in my opinion.  The only comments I made involved other equipment that was clearly attached to his device with high pressure hoses.
As for the reporters, I am fairly confident that not one of them would know a hydraulic pump if it bit them in the butt.  I would not use this as any "evidence" that this device works.
LarryC
Quote from: Pirate88179 on September 25, 2008, 08:22:59 PM
Larry:
Hello Bill,
Not all directed at you, but actually the photo that you were using is the latest machine design as far as I understand.
And yes, a reporter may not know a hydraulic pump if it bit them in the butt, but they would notice if any external device is attached to the machine and question relentlessly.
However, I do agree with X0013 that it is a pool pump below the rear table, as I have seen several, and with AB Hammer that it is an optical illusion that they seem connected.
The machine is on approximately a 4'H X 4'W X 6'D base, the table with the pool pump is to the rear of the base. Look at the way the top of the machine base on the upper right side veers to the center of the picture. If that bottom small pool pump hose was hooked to the rotating arm it would get ripped off.
But, If you don't agree, then we agree to disagree.
Now, I am not familiar with high pressure hydraulic pumps, but why does the hose just below the center seem to crumple up like a garden hose?
Also, I would appreciate your input on the cylinders and hoses on Bob's machine, but please disregard the rear pool pump hoses.
Thanks, Larry
Pirate88179
@ Larry:
I appreciate your attitude.  I still believe the pump in the photo was connected to the device, but, of course, I could be wrong.  So we can agree to disagree on that.  As far as the hoses you mentioned, I am not sure which photo you are speaking about?  Would you mind posting the photo and maybe put an arrow to the hoses or just describe where they are?  I just want to make sure I am not getting confused on which photo is of which device.  I have seen a device with the high pressure hoses and then I have seen a device with just regular plastic air lines of much smaller diameter.  I believe it is normal for a guy like Bob, or any of us for that matter, to have several variations of a device as it progresses through its design stages.  This part does not bother me at all.
On the photo in a recent above post, I do see the "switching" mechanism someone mentioned on the shaft of the device.  Yes, to me this appears to be a timing control device of some kind, which makes sense.  What I am not sure about is where the power comes from to run these pick-ups?  I know he has it hooked to a generator but the output from that would, to my way of thinking, be too high, and also, not consistent as it would vary with rpm's.  If it were me, I would run the switches off a battery and then dump the generator juice into the battery, or bank of batteries.  What are your thoughts on this?
Again, I appreciate your attitude in wanting to discuss this as opposed to argue about it.  The only person that really KNOWS for sure is Bob.  I guess the best the rest of us can do is to speculate, guess, discuss, and exchange ideas and theories.  Take care.
