New accelerating gravity wheel ! Converted video from www.newenergymachine.com !
Started by hartiberlin, May 11, 2007, 12:49:03 AM
LarryC
Quote from: unity2zero on October 16, 2008, 02:08:44 AM
Jason
I think you are right. Bob is using external compressed air as an enhancement for his gravity wheel. The vid photos of his wheel clearly shows an air cylinder on each end of the connected weights. If you check his website, this is what he had written:
"This new engine is the product of years of research, frustration and
perseverance. I found that using the perpetual motion approach limits
the amount of usable energy available. An internal combustion engine
can be enhanced and will produce more power by installing a turbo
charger. This unit will use some of the initial power produced by the
engine, but the end result is far greater. The same process is used
in this unit but because it uses Gravity rather than fuel, the enhancement
system is much different."
He is comparing his flywheel to an IC engine and its turbo charger as an enhancer. Likewise he is using compressed air from an external source to "charge" or enhance his gravity wheel. The big question is whether the wheel would give out enough energy to operate the compressor to give energy back to the gravity wheel. At best, this is an energy "tank circuit".
Okay, that is one theory, here's another.
It is based on Bob's statement:
"Once the weights are past the ballance point they accelerate and generate many times their weight that creats the the energy needed. The faster rotation the larger the force. With out the springs and shock absorber it would destroy itself."
So when he stated:
"This unit will use some of the initial power produced by the engine, but the end result is far greater. The same process is used in this unit but because it uses Gravity rather than fuel, the enhancement system is much different."
I believe he is talking about the springs capturing the CF sling force after the balance point and then releasing it at the beginning of the lift phase.
Regards, Larry
Xaverius
Quote from: LarryC on October 16, 2008, 11:22:05 PM
So when he stated:
Regards, Larry
Interesting point, sounds very logical.
helmut
Hello
Things develop quite well
Bob has started a new 1th page
In one or two month he will finnish his demomashine
seehttp://www.newsourceofenergy.com/
noonespecial
@all
Bob's new demo unit is suppose to be the start of his initial production units. Apparently he was successful in getting a local company to start producing them. I'm hopeful that his website will present clear photos or video of its operation.
Regards,
Charlie
Xaverius
Quote from: noonespecial on October 19, 2008, 08:31:41 PM
@all
Regards,
Charlie
Sounds great, let's hope for the best!
