New accelerating gravity wheel ! Converted video from www.newenergymachine.com !
Started by hartiberlin, May 11, 2007, 12:49:03 AM
rensseak
Hello all,
did already someone of you take a closer look to the video?
here are some pictures i extracted
helmut
Quote from: aaron5120 on June 18, 2007, 05:56:23 AM
Guys,
There are more videos regarding this interesting gravity engine. These videos show the older version of bobmary's machine. You can see the mechanism easily.
The other one is the fuelless machine from the same inventor.
Links:
a:  http://www.youtube.com/watch?v=xWIN_b95GoI
b:  http://www.youtube.com/watch?v=ZG_3tb0QG5Q
c:  http://www.metacafe.com/watch/333921/fuelless_engine/
For this last video, you must go to metacafe.com and search for "fuelless engine" to see the video.
Aaron
Hi Aaron
The Videos are not more on You Tube
Who can provide a Copy?
Helmut
d3adp00l
I am kinda curious why the "table" directly in front of the camera jerks around when the machine starts to rotate, and stops when it stops. I wonder why the two are connected, looks like some air compressor connections on it.
History is full of people who out of fear,
Or ignorance, or lust for power have
destroyed knowledge of immeasurable
value which truly belongs to us all.
WE must not let it happen again.
-Carl Sagan
hartiberlin
Hi All,
Bob is back from hospital,
he just wrote me the following:
Hi Stephan. Just thought I would give you a little message and let you know I am back home again. I still go to therapy but things are comming along.
The compressor in the movie is what I was the machine was driving to do some usefull work. The machine wasn't ballanced and the board that is moveing is used as a shelf or small table.
There are no hoses or airlines conected to it.
The way to lift the weight to the opposit end is at the 4:00 oclock position an  arm from the centre, on a cam mecanisum to the end of the arm (2.5 ft) is forced around and lifts the linked weights 1" farther than 1/2 the total travel. Centricical force will lift it the rest of the way. It acts like a leaver 2.5" to centre and 10" past.The farther it pushes the weight from the bottom the easier it gets.The first 2" is the heaviest. The spring mecanisum helps at the first of the upward stroke.
A locking pin is used to release the springs.(springs have to be compressed for the first revolution) Springs
On the pictures that are labled, the belt is a steel bar joining the two weights.
The spring mecanisum is at the end of each arm. This is a must, as well as the air shock to stop the weights from impacting the end.
I hade help from a friend,George,who was an retired Engineer who designed the cam system as well as other parts.
I am going to go now. I can only type wih my right hand and it takes forever to type this. Soon I will be back to two hands.
Don't worry about the little bit of trouble there was, everything is ok.
I will be in touch......Take care Bob.
helmut
