New accelerating gravity wheel ! Converted video from www.newenergymachine.com !
Started by hartiberlin, May 11, 2007, 12:49:03 AM
AB Hammer
LOL I like it when he cries help!! LOL
The biggest problem I am looking at is, it is over complicated. This can cause more to break down. I am sure the thing is noisy and look how it shakes around. For starters he need a much greater structure just to run it. But he is still to be watched. IMHO
Alan
Alan
vince
@ Alex,
The patent which can be found in one of the earlier posts shows a general arrangement of the concept. The machine has evolved in several forms but the basic idea is simple and not really as complicated as it may appear.
Basically he is shuttling a heavy slider weight to the top of a rotating arm or track.  He started with Pneumatic cylinders but has progressed to hydraulics. The cylinders are attached to the rotating arm or track on one end and to the slider at the other end. Air or oil in the later variations is fed from a electric motor/ hydraulic pump power pack thru a swivel valve in the center of the shaft and feeds control valves at each cylinder. An actuating valve is placed on the rotating arm and is triggered by a lever which is fixed to the base structure.  When the arm rotates to a preset point on the high side the trigger valve is activated and allows oil or air in the earlier versions to force the cylinders to move the slider to the highest point in the rotation and make that side heavy, and since the low side of the slider has moved to the center most position the opposite side of the arm is now light.  When the High side of the arm falls thru the arc because of gravity it again triggers the valve to shuttle the slider to the opposite end of the arm repeating the cycle.
Various versions of his machine show different triggers for actuation.  On one version he used electric solenoid valves fed by a commutator on the rotating center shaft. The valves were 12 volt so that is why you saw a auto battery in that version.
The reason the machines are so massive is that more weight means more torque and centrifugal force as it rotates.
In the three arm version that he has, the slider weights are individual and not attached to each other. These have individual triggers for each arm to shuttle the slider/weight to the high side at approximately the 12 o'clock position and to a more central position after the 6 o'clock position for each arm.  Same concept only a more elegant design.
The design is quite sound and obviously produces a lot of torque.  You have to admit that no one would put that much time and money into a project without having real and productive results. This is no stick and glue project. No one would make so many versions of a design if they were not confident that the net force gained was not worth the effort.
Watch this man. This is a real contender!
Vince
Alexioco
So at the end of the day, its electric assisted to raise the weights up? Where is there excess power coming from?
Alex
The love of God is great and true,
A special thing for Him and you,
A perfect friend, a Father too,
Lift up your hearts for He is true.
vince
Although he never says it, the claim is implied that the amount of electrical power used to run the power pack to move the slider is LESS that the generator is producing due to the torque added from the falling weights and the centrifugal  force components in the equation.
I really doubt that he would have gone to these lengths to make so many expensive examples of the machine if the results were not positive.
Maybe a more appropriate name should be Electro/Hydraulic Gravity Assist Motor Generator.
Vince
Pirate88179
