Meyl powers boat with Tesla waves !
Started by hartiberlin, May 13, 2007, 11:52:12 PM
dl
It is not necessary to be 7Mhz to do that. Meyl's experimental kit has 3 coils: A,B,C. In each type of coil, there are 2 frequencies to make the receiver's LED on. One of the frequencies will see the receiver LED's off at far range and the other will not. The one that does not is claimed by Meyl to be scalar wave.
You can simply make the coil just as Tesla's patent US645576. Meyl did it on a double sided PCB. One side is the primary and the other side is the secondary coil. Then you want to look for a metal ball. I think you can possibly try a door knob. I never did. The important equipment is you need a signal generator that covers a wide range so that it can tune into the coil resonant frequency. Sine wave is good enough. Meyl's experimental kit covers 900Mhz to 13Mhz for his coil.
Tesla mentioned that the natural medium can be one side through the air and one side through the earth or sea. Yes, I can transfer the power over the water in 30cm range using his experimental kit. Meyl said, the range can be extended with higher voltage amplitude. I do not have power amplifier to vary the voltage to extend the range. Bear in mind any object that has similar resonant frequency and shorter distance to the transceiver than your receiver could absorb the power. This is mentioned by Meyl in his book. Please search for his books in www.scribd.com. You will learn a lot from there.
turbo
Meyl is in error.
He does not understand the concept.
M.
Overmind
Quote from: mikewatson on October 04, 2008, 08:00:24 AM
I do not think this has anything to do with overunity at all. It is about ground power transmission which Tesla pioneered [...]
Correct. Power can be transmitted over one wire by using potentials instead of currents, but it's not over-unity. It has way less losses then standard power transmission, though.
Jonnys007
hi all i have read all meyl books gone through all tesla patents and i will b finished the scalarwave transponder  really soon ..... i have all the equiptment now ... lol thats wat took the longest.... and i now have the conditions for resonance.... so stand by ... if this work this is b the power sourace for a flying saucer my engineering freinds and i are also makin .... based on tt brown electrogravitics... powered via scalarwave.....so stand by.. i will b posting result when i get the 2 secondary coils finished.....
@Jonnys007, I think you'll have trouble without a ground connection. You could perhaps lose ground all together but you'll probably need to increase frequency for that.
