Controller circuit for Hilden Brandt motor needed..
Started by hartiberlin, May 19, 2007, 12:56:53 PM
wattsup
@Jack
I read the bad news. Son of a gun. I am soooooo sorry to hear this and I'm just flabbergasted. Are you really sure? I mean mistakes are always made with these diagnosis.
My brother is a Homeopath and in the family we know much about alternative healing, etc. I have had all my metal fillings (15 or so) removed for the polymer type. Imagine when this is removed the dentist and assistant wear special masks, they put a mask on you and cover the tooth and mouth so well because of the dangers involved. And this material had been in my mouth for so many years as is, mashing away at my food.
I am in the water treatment field for nearly 30 years now. One major comment I usually tell anyone is filter your water or you will be the filter. Most especially city water. At my home, I use reverse osmosis (dirt cheap on eBay) and add a few drops of a liquid multi trace mineral concentrate to each pitcher full before we put it into the fridge. If you have well water that has manganese, until you correct the problem don't let your pregnant wife and younger kids take showers because this heavy metal will vaporize, kids will breath it (also mother to fetus) and like anything else you breath goes from the lungs first to the brain where it lodges and can cause learning disabilities and tremor type problems. So imagine the heavy metal fillings in your teeth also let off vapors when you chew, you breath, it goes to the brain. Metal and neuro electric impulses don't go well together.
Here are some more key words to look into;
- Lorenzo's oil - work on the mylene outer layer of nerves.
- Olive oil - Oleic acid
- Oxalic acid  - most people lack it.
- Lack of Selenium in the daily diet due to low selenium levels in crop lands.
- Look in Google with (+nexus +selenium) and click on the first two cached versions.
- Stay away from citric acid, meat, dairy and anything with refined flour or sugar for at least 6 months. Your body needs a break.
- Liver and kidney cleanses are also important with a combined colonic irrigation. Also
- Eat less, live longer.
I know this is impossible to say but there must be a way you can beat this.
This is also a good video that had blown me away. It's 2 hours.
http://video.google.com/videoplay?docid=2095786730805958061
I want to try it as prevention. This man is using electric DC current sent to the wrist to kill off all parasite, bacteria, virus, microbe, fungus, etc. Within 3 hours all the blood in your body flows through your arm, gets exposed to the current 4hz impulse 4-5ma via two pure silver wire probes for 3 hours a day for three weeks. It's small so you have it taped on your arm so you can still work and people won't even know it is there. I will try it. If you took all the parasites, bacteria, virus, microbes, fungus and all other foreign and often called alien forms of life in a man weighing 160 pounds, you would have 2 pounds worth. That's 2 pounds of micro bad guys just weening off our bodies, getting stuck in our joints, hiding in our lymph nodes and overtaxing our auto immune system. We are all such hospitable hosts.
About your fantabulous motor, it's too bad that Honk tried his best and still there is no progress. Now your bad news just compounds this by millions.
One of my good friends and close OU collaborator owns a complete machine shop that generally produces medical grade apparatus and parts using all the metal types. They do real nice work. If you ever needed a collaboration, to build another unit as a parallel effort, I could look into it and I think he and a few other guys that I work with locally in OU may have an interest.
I think your motor could work with some good old Tesla know-how and just bypass the EE part for now. Efficiency is in the simplicity and robustness of the design. If Tesla was here today and he saw your motor, don't you think he could have operated it at its peak performance using 1900 technology. Something to think about Jack.
Right now, like everyone else, I don't know how your motor works exactly, but I would assume at this stage that you are not using the magnetic field shift to control the switching. I think you were using points and then Honks controller. Now what would Tesla do, is the question here Jack. Tesla has shown us in his patents that there is a way of running a motor so that the energy expended returns to the source. But from my overview of what's happening on the motor scene, if you use solid state for switching, you will inevitably have to have a main ground line going through a SS component, and then it gets fried. For your motor to work, I feel it has to have both positive and negative on a circuit that does not let the current stop. It has to go in, produce, return, go in, produce, return. SS will go in, produce, and fry.
They can't handle the return to the source because they stand between the source and the load. Standard motor controllers work since they are not concerned about energy efficiency our returning energy to the source otherwise they would also fry. I remember I just unplugged a running motor from an inverter and my 1200 watt inverter fried. I also remember our 240 volts dc 3hp motor was switched on without energizing the rotor field and the flyback just pulverized this heavy duty start switch.
We are touching on this subject in The Tesla Project thread. I tried one of the circuits made by @AC on a small DC motor. With one impulse the motor turned to the right and used the return to the source to turn it back to the left without consuming any more energy. lol. So you are getting two motions for the price of one. Something to think about. If you plan to give your device to the university, maybe have them look that thread over for some ideas.
For myself and I am very sure from everyone here at overunity.com, I wish you the best in health and happiness and success for your grand vision.
hartiberlin
Also eat lots of algae like Spirulina,
helps a lot to get toxic stuff out of the body.
Regards, Stefan.
JackH
Hello wattsup,
Well I have had to dr. tell me I have ALS, one in Cleveland and one in Columbus.   I the last six months I have lost 40 lbs of muscle on my body.   My arms look like I am 100 years old.  I have lost alot of my strenth in my arms and leggs.
I feel like that guy on TV, I have lost over 40 lbs of weight at the tewnder age of 63.
I have studied electromagnetics and purmanent magnets for over 25 years, every thing I could read, I read.  I also have alot of work in testing different things.   I used to be a prototype maker in the maching shop in Detroit.  Thats were I learned the machine shop.  In that shop I built mixers, drills, and all kinds of stuf. In there I learnt to build mold for plastic, build motors, and just about everything.
If anybody wants to help me with the motor, bring them on.   I know that this motor is running at over 250%.  And it would be a shame if this motor died with me.   I do not know if OSU is going to pick it up or not.   I havent heard from them lately.   I took it up to show them and I ran into a bunch of none beleavers.   I have a big motor in my shop that uses 2" by 4" magnets. This motor will run on the same current(90watts) and produce much more power. I think it will run at over 300%.   Thats the great thing with this motor, no mater how big you make it it will still run on the same 90 watts and produce alot of power.  But I don't have the money to buy magnets for it.   I have stoped selling shares of the company because I am dieing.  The Dr. gave me about 3 to 4 years of life, they also said that I would loose my voise in about 8 months, and I would live in a wheel chair the last 2 years of my life.
Hello hartiberlin,
Can I ask you what algae like Spirulina is?  Can you buy it in the USA?   I have been trying to buy something to clear my body of toxins, but have had no luck.   I have had a machine shop for about 7 years now.  I work with aluminum alot, at the end of the day my hands are black with aluminum, my hands are scarred up and I think I am being poisioned by this aluminum.   But I cannot get anybody to take a toxins report on my body.   The Dr. in Columbus did not take any tests at all, but yet he come up with ALS.   I would think you would need to take some tests to satisfy that I had ALS and not just that I was poisioned in some way.
I want to thank everybody for being concerned about me, I really appreciate it.
Thanks,,,,,JackH
JackH
Hello All,
Another thing I wanted to tell you all.   When I went to OSU they told me that they hadn't sent any body down to test this motor.
A white van showed up one morning with OSU stickers on the doors.  Two young men cam out of the van and said they were from OSU to test the motor.   Well I had no reason to question them so I let them into my shop.   They put a dino on it and tested it.   I had to build the test stand for the dino and hook it up to the motor.   It tested out to just over 1/2 HP on 90 watts.  They said they would get back with me at OSU in a couple weeks.  Was this the government or who was it.
I was drinking a cup of coffee while all of this was going on.  I maybe think they may have poisend my coffee to get me out of the way with this motor.    I am the only one that knows how to put this motor togather to make it work, my wife does not know how to build it or neather does my step son.
Thanks,,,,,Later,,,,,Jack W Hildenbrand
wattsup
@Jack
Sad to hear. If you lost 40 pounds of muscle, you're body is trying to get fed from your body because it is not getting it from your digestive system. The first thing I would do is find a "competant" naturopath or homeopath and/or start getting a few colonic irrigations since that is where most people start having the problem. Some people could not even walk anymore and after two of these, they are back on their feet. You have to realize that the colon has been taxed all your life and it is incredible how much matter can get physically stuck in there blocking the nutrient absorbing cavities.
Also, if you are a fast eater, chewing only a few times before you swallow your food, this is really bad. You have to take your time and chew at least 20-30 times per mouth full. Your stomach does not have teeth and most of this unchewed food will just pass into the digestive system and never be used. Actually it will ferment more then anything else. Digestion begins in the mouth.
About your motor, my regular e-mail is wattsup1004@hotmail.com and if you have a picture and some general dimensions of the device, that I can show my group, this will simplify things. I can state here that it will never be left with anyone and it will never be posted anywhere as this is confidential to you. Also, if you send me a direct e-mail, I will then respond to your e-mail address with my full personal contact information so you can contact me anytime you want. Geez, it's about time this motor saw the light of day.  I would also urge you to take photos of the unit, any documents should be copied and given to a notary or other person of confidence for safe keeping. Also, what is the status of the device, is it in patent pending, etc., and you mentioned you had sold shares in your company. I am puzzled that people would invest in this without knowing exactly what the device does, how it is made, etc. Is there not anyone near you that has the technical skills to understand the device. This is not good because you have your lifes works in there. About the two men that came to measure the device, this is troubling that the OSU did not know anything about this. Is this recently?
