Controller circuit for Hilden Brandt motor needed..
Started by hartiberlin, May 19, 2007, 12:56:53 PM
JackH
Hello Carl, Honk, Stefan,
Well I think what got be in to this ALS was, when you go into fight or flite, your emunsystem shuts down.  No body would beleive me when I said this motor was over unity.  Even OSU was a bunch of none beleivers.   I have call Don Freemon from the government and he said it was impossable.  I have call all kinds of people and no won will beleive me, no wone will even go as far as test it..  The only one that beleive me was the ones that said they were from OSU and tested it with a dino at over 1/2 HP.  And to this day I do not know were they came from.
Right now I am consitrating on my health and do not want to get involved with the motor untill my health is in order.  I am doing the Healing Codes,  (www.TheHealingCodes.com).   Right now I am taking Spirulina, Chlorella to help get the heavy mettals out of my system.  And also Neeroga to get my emunsystem going again.   I am starting to feel better now, and I even starting to gain weight, my mussale giters are going away and I beleive with GODs help I will beat this ALS in my body.
I just do not want get into the motor right now, because it was what got me into this messssss.
Thanks to all,,,,,,,,,,,,,,,,,,,,Jack W Hildenbrand
JackH
Hello Stefan,
I was wondering if you could give me some kind of a drawing on how you would put these P600 diodes in the sercit.   When I get to feling better I may give them a try.  Wright now if I put a diode across the caps and hook a 100 watt light bulb across it the light bulb will burn out fast.
Thank you,,,,,,,   Jack W Hildenbrand
hartiberlin
Hi Jack,
here is the circuit for one of your motor coils.
You have to make these 3 times and put the 3 points together in a 120 degrees
arrangement
on a plate, so that you can change in angle relationship to the
rotor.
The camshaft will then open and close the points
mechanically.
This way you can control,
when exactly the coils are energized.
Maybe it would be even beneficial to
use nosuppression freewheel diodes
and just have 60 Watts fluorescent tubes parallel across the
coils and let the contact points just spark.
Then you have the Newman effect.
Be sure to use then graphite and copper as the contact points.
The fluorescent tubes will save your coils from oversparking and shortout
and the BackEMF will be converted to flashing
of the fluorescent tubes.
But maybe just try first this P600 freewheel diode circuit.
Good luck for your health,
yes Spirulina and Chlorella are great...
Regards, Stefan.
JackH
Hello Stefan,
I printed out the drawing and your message.   I'll give it a try maybe next week.
Thank you very much,,,,,,,,Jack W hildenbrand
wattsup
@Jack
Glad to see you are using the Healing Codes. I will be sending you a donation soon to help out with the lawyer and I have put a Help Jack signature on my posts. Suggest others do this also. And if there are any money men out there, Jack needs your help, now.  (A few mil will do. lol)
Regarding your motor, if the three coils are not being energized at the same time, that is if they are being energized in succession, then why not think about sending the flyback of the first to the second, then the flyback of the second to third, then the flyback of the third to the first. This way you let the coils handle the flyback by using it, not by wasting it. If the points where two way, one NC and one NO, this could be done quickly. Or two sets of points would also do it. You could probably run the same motor with 30 watts instead of 90. Then maybe they would believe.
Anyways, get well soon so you can finish this motor.
