Controller circuit for Hilden Brandt motor needed..
Started by hartiberlin, May 19, 2007, 12:56:53 PM
Honk
Thanks for that positive feedback. It gives me extra power to complete the controller.
I'd like to correct the name of the feature Flux Measurements Outputs On-Board.
To be more correct the name should be Flux Response Outputs On-Board.
This output makes it simple to see the rise and fall times of the coil current on a oscilloscope.
The Flux Response current rise time can be fine tuned by a small pot inside the Controller.
This is not accessible from the outside. It's set when tested and if tampered with while
running a motor and without having an oscillosope and knowledge the result can disastrous.
Funny that you can read Swedish!
Where are you from?
Regarding the muslims, I don't mind them as long as they don't make any trouble in Sweden.
Most of them don't but those who do I just feel sorry for.
If this motor really is OU then then we will get rid of most oil dependence and the world
might not mess around and upset the middle eastern countries any longer.
Magnet Power equals Clean Power
Thaelin
Hi Honk.
     Svenska  Yag!
   My family came to the states from stockholm    ;D
sugra
Honk
Another status report on the controller.  ;D
I have mounted and tested the very important AC-DC convertor that will fit the
incoming voltage to the special needs of the motor. It makes self running possible
if the motor can deliver more out than in. It must be efficient to not waste energy.
Well, I'm happy with the stability and efficiency performance of the AC-DC.
It tested to be 92.2% efficient at 110V input and 45W output. It can deliver up to 85W.
You can't buy AC-DC adaptors with this level of efficiency. They are usually 82%
efficient at most (Premium converters).
Honk
Hello all.
The controller is finished. Iv'e tested it and it is working fine.
There's still some small issues that I will have to check more thoroughly
before I send the controller overseas to Jack to be tested on his fine motor.
Next week I will have vacation. I estimate I can send it the week after that.
Here's the pictures:
dlwammo
That's impressive honk.  A really beautiful piece of craftsmanship!
If it works anything like it looks, that motor should purrrrrr...
Dan
Don't mess with old farts... age and treachery will always overcome youth and skill!
