Controller circuit for Hilden Brandt motor needed..
Started by hartiberlin, May 19, 2007, 12:56:53 PM
JackH
Hello thaelin,
You are correct.   The second pull is the most powerfull one, it pulls between the magnets.
Later,,,,,,JackH
Elisha
Jack, you are a Master.
You have considered to use coil mirror in the winding of the valves of the new motor?
The patent 4806834, please take a time and see mirror coil, http://patft1.uspto.gov/netacgi/nph-Parser?Sect1=PTO2&Sect2=HITOFF&p=1&u=%2Fnetahtml%2FPTO%2Fsearch-bool.html&r=6&f=G&l=50&co1=AND&d=PTXT&s1=4806834&OS=4806834&RS=4806834
also can see in google patent search http://www.google.com/patents?id=i3pNAAAAEBAJ&dq=4,806,834
They say efficiency of almost 100% can be achieved.
JackH
Hello Elisha,
Well I wouldn't say I was a Master.   But I have worked on just about every kind of motor there is in the past 8 years, with my machine shop.  I have also worked on this kind of thing about 27 years, in somebody's machine shop.  Howard Jonson got me started.
The only thing that showed overunity is my motor, none of the rest of them showed overunity.  I worked on all kinds of motors, especially Flynn's motor, I could not get them to put out more power than input, I could not get them to put out more than 98% efficient.   I am thinking of winding Baffler coils for my new motor, if I can get my hands to work.     Thank you for your praise!!!!!
Later,,,,,JackH
aether22
How is the ALS/healing codes going?
Be sure to give your body other stuff it needs to fix the problems as well. (sunlight, water, good nutrition including chlorella/spirulina)
Sometimes these things work immediately, other times it takes a year. (My mother reports feeling better than she did 25 years ago or more from being on some of this stuff, but it took most of a year)
aether22
BTW there is another system that is very similar, might give inspiration:
http://www.emofree.com/Articles2/ALS-aspinall.htm
http://www.emofree.com/Anger-management/ALS-anger-lund.htm
Though the healing codes are better since a right out negative result for ALS has been established unlike EFT, however this should serve as encouragement as they are the same type of symptom.
Incidentally I found this too: http://www.evenbetternow.com/als.asp  for what it's worth.
