8 WATT INPUT ELEC. ENERGY 50 WATT OUT EL. ENERG
Started by MACEDONIA CD, May 27, 2007, 07:22:14 AM
MACEDONIA CD
HI  TO ALL  IN THIS FORUM
3 MOUNTS   I TRYING TO MAKE SOMETHING  ,NOW   MAKE SOMETHING  VERY GOOD  ..ALL YOU NEED IS  TO HAVE A    1  OSCILATOR WHIT ABOUT 150 Khz,and a secundary out coil whit   SPEAD DIODE  WHIT BIG CAPACITATOR  ABOUT 20000 uF ..ITS  WORKING  LIKE THIS...
  MAKE  I 8" COLECTOR COIL  HO  IS ABOUT 40 TURNS  , THEN  AROUND THIS COIL MAKE  ANOTHER PRIMAR COIL  WHIT  20 TURNS THEN  IN THIS PRIM  COIL BRING THE OSCILATIONS  WHIT  150Khz  THEN IN THE OUT COLECTOR COIL  IF YOU BRING  A BULB   12 VOLTS  YOU CAN SEE THAT  NOTHING HAPEND   ........  IF YOU WANT TOLIGHT  THIS BULB   ALL YOU NEED  IS  A SPEAD   4 DIODE   WHIT 1 CAPACITATOR  , ABOUT  20000uf   ............................. T H E N  YOU HAVE  WAIT
JUST   ABOUT 8 SECOND  THEN THE CAPACITATOR  WHIL CHARGE MORE POWER  THEN INPUT  THEN  YOU  CONECT THE  BULB  TO THE CAP  THEN THE BULB  WHIL  START TO LIGHT  VERY STRONG   ABOUT  2 SECOND   ,,,,, AND THEN  ITS  THE SAME   PRINCIPE AGAIN    .................................................................................
I T S   VERY IMPORTANT   THE  SPEAD  DIODE  IF YOU  NOT  GET A  SPEAD DIODE   YOU  GET NOTHING     THIS  DIODE  IS  A HAVE  SMALL  RESIST    ABOUT  100 OHM  ,  BUT  IF YOU HAVE  STANDAR DIODE   THIS RESIST  IS   500 OHMS   ITS
V E R Y   I M P O R T A N T   IF YOU GET MORE SPEAD DIODE   IN PARALEL CIRCUITS   THEN YOU GET SMALL RESIST  FOR THIS OUT  COLECTOR   150Khz  ...
AND  ANTHER  THING  ..  IF YOU BRING MORE DIODE  IN PARALEL  THEN  THE CAPACITATOR  WHIL  CHARGE MORE FAST  ,, VERY IMPORTANT  WHEN YOU CHARGE  THE CAP.  THE BULB  MOST NOT CONECT  TO CAP  ,, WHWN YOU CHARGE MAX. CAP  THEN YOU CONECT THE BULB...
IN THIS DAYS I SEND PDF   AND  IF I CAN  THE VIDEO FILE  TO SEE
THANKS    MACEDONIA  CD
Dyamios
Sounds to me just like a normal transformer, though I may be getting the wrong gist of this device.
Can you show your math involved in the calculation of Input and Output energy?
I would like to see how you came to this conclusion.
IdentFlyObj
Great! Overunity!
.....(or overignorance?).....
bye  :-X
MACEDONIA CD
OK   PEOPLE  IF YOU  DONT BEALIVET  YOU  SE     THE   VIDEO CLIP   NEXT  DAY  WAIT   THAN  YOU  CAN SEE  THAT  IS POSIBLE  TO MAKE  THIS    CAO  CAO  CAO
   EUREKA     ,,,,  HEY  DID YOU NOW  THAT   THE   Nikola  Tesla  is  from  Macedonia   his  father  is  from  Macedonia    ::)  is true   bealivet
Veliros
By no means are we accusing you of fraudulent claims, but the description provided doesn't seem to prove how you concluded that 50 watts were being produced from 8 watts of input energy.
Also I was under the impression that Nikolai Tesla was from a military front in the Austrian Empire. I don't think that Macedonia was ever part of the Empire, but at one time Austria-Hungary did occupy the Macedonian lands under their consent for a short period (I believe in the late 1800's). Tesla then moved to France and then to the United States.
Granted Tesla's father was Serbian, which did include some parts of Macedonia from the 1800-1900's, so you can state that was Tesla has somewhat Macedonian ancestry, but saying he was from Macedonia wouldn't be entirely true.
Cheers!
