Wankel Magnet Motor
Started by molux, May 30, 2007, 04:15:17 PM
joe
Salut Molux,
J'?tais entrain de regarder les videos de ton moteur Wankell et je vois que dans l'exemple 2a le disque tourne plus lentement que dans 3b. As-tu chang? la configuration des stators? Peux-tu m'expliquer un peu qu'elle est la configuration qui fontionne le mieux pour que le disque tourne plus rapidement?
Merci!   Joe!
molux
Hy Joe,
Ok, i think we can't speak french here, because it's an international forum and there is a section to speak french, so it start a french thread here if you want:
http://www.syscoil.org/forum/viewtopic.php?t=28
We are going to be "rouspeted" if we continue...
QuoteJ'?tais entrain de regarder les videos de ton moteur Wankell et je vois que dans l'exemple 2a le disque tourne plus lentement que dans 3b. As-tu chang? la configuration des stators? Peux-tu m'expliquer un peu qu'elle est la configuration qui fontionne le mieux pour que le disque tourne plus rapidement?
I'm looking your video ans i see video 2a seems to turn slowly than 3b video. What did you change ? can you explain me what is the better configuration for best speed
Yes, you have right, on 2a video the magnet is put under the CD with scoth
The magnet is so hight, Under video 3b i cut the CD to put the magnet in the middle
like that:
It increase greater efficency than first setup.
For the explaination of the better setup, i trying some configuration, you can see all in video under youtube.
Here some other experiment:
Two ramp trying:
http://www.youtube.com/watch?v=Ixxfb0LL-rA
A new ramp (so bad)
http://www.youtube.com/watch?v=2qhIChHgrtE
I have to try other setup, perhaps i have to try with inclined rotor magnet or put the stator magnet on the height to reduce the magnet tangent size.
Molux
Paul-R
On the subject of back emf, it is important (I think) to
remember that IT IS YOUR FRIEND. Do not block it or
soak it up in a resistor. I believe that Tom Bearden said
somewhere that this is the energy that will make your
device over unity. (N.B. the Minuteman Missile story).
Paul.
molux
Hy,
QuoteOn the subject of back emf, it is important (I think) to
Paul.
Right, it's writen
Here a simple experiment to view the using of the coil for generator:
http://www.youtube.com/watch?v=NtTRdQQUs_I
Here an repultion equilibrum probleme
I push out a magnet on a dead point and the dead point stay here ! We can see it's a repultion equilibre
There is a particulare shape to this well and forget the equilibrum point... can someone know the answer ?
Molux
Paul-R
Are the stator magnets of exactly the same strength?
The rotor should not stop in that position. You need a
magnet at Magnet Position 3. Maybe you should take
one off the end, and try that instead. Also, you will need
enough magnets on the stator to reach around to the
start (less a little room for the electromagnet).
Paul.
