Magnetic spinner magnet motor on youtube
Started by hartiberlin, June 04, 2007, 07:12:04 PM
cchance
Very sexy, but technically if you can get 90deg covered with neo's you should be able to use 8 stators... 2 at every 90deg and maintain the rotation i'd really love to see more shots and videos of one of these in action.
Bruce_TPU
Hello Tseung,
Thank you for sharing Wang's story.  It really is amazing.  I hope that his health has improved.
It is wonderful to see "Lead Out" thinking concerning OU.  I am excited to see a video as well.  Thank you for the detail.  It would be exciting to see this replicated here on this forum, with your help, if you and Wang thought it okay to give that amount of help and detailed information.
Warm regards,
Bruce  :)
NerzhDishual
Hi ltseung888,
Thanks a lot for your valuable informations.
I did apreciate "The Juicy story of Wang Shum Ho" :)).
In your Magnetic_Motor1.doc you are talking about pendulum.
This let me think about the Veljko Milkovic device.
Is he not using ?the pendulum with a pulse force at resonance??
If your are not aware of this machine you can find more about it, on:
http://www.overunity.com/index.php/topic,1763.0.html
I have also downloaded and put some videos on:
http://freenrg.info/Milkovic/
Best
Nolite mittere margaritas ante porcos.
ltseung888
Quote from: NerzhDishual on June 30, 2007, 05:50:42 PM
I have read the Milkovic information.  He is in fact using "the pendulum with a pulse force at resonance".  So far he is applying the Pulse Force externally.  He can demonstrate that it is easier to swing the pendulum than pushing a pump etc.  He can demonstrate that a small pulse force through a hand held light could light up eight lights.
However, he might not have digested the Lee-Tseung Lead Out theory thoroughly yet.  If he fully understood the theory, he could have a feedback mechanism so that he could keep Leading Out gravitational energy without the external Pulse Force.
His device is excellent in demonstrating the Lee-Tseung Theory.  We hope to work with him to perfect the feedback mechanism.
The feedback mechanism for pure mechanical systems is best achieved via coupling of two or more techniques.  Wang Device is an example.  Steorn Toy is another example.
NerzhDishual
Hi ltseung888,
Thanks for the particulars.
I whish I also had fully assimilated/grasped the 'Lee-Tseung Lead Out theory' so I would be able to build my own Bessler-like machine! Would I not be?
Best
