Magnetic spinner magnet motor on youtube
Started by hartiberlin, June 04, 2007, 07:12:04 PM
Omnibus
QuoteI forgot to tell you that I held the stack  magnets about an inch apart when it worked the best, maybe a little less. Also held the stacks about an inch to 1 1/2" above the spinner.
Did I understand you correctly? You are holding by hand a stack of magnets while the spinner turns and if you suspend the stack of magnets in the same position above the spinner withou touching it by hands it stops spinning, corret?
kidsicu2
Omnibus
No read back to the 28th. Used two stacks of 6 smaller neos to simulate what I saw in the video that started this. He used 2 bar magnets as the stator. I used 2 stacks of neos and opposed each stacks poles so they oppossed fields when held parallel to the rotor/ spinner. I held them close enough that they strongly opposed each other and varied that distance till I got results. i also played with the height that way as well. I did it by hand to hasten the process of testing and got results. Now to build something to do further testing.
This should be easy to duplicate. My son held the spinner while manipulated the stator?
ds yin/yang
ltseung888
Dear chrisC,
Please check http://www.wipo.int/pctdb
PCT/IB2005/000138 titled Extract Energy from Gravity.
Omnibus
@kidsicu2,
This will only be of interest if the rotor turns without you or anybody holds the stator in hand. Numerous spinners with handheld stators have been proposed none of which is of any interest.
kidsicu2
omnibust
I really dont care if you dont think that its of any intrest to you or not. I f you dont understand the concept of experimentation thats not my problem. Hand held was the fastest way to test what the spinner mtoor concept I saw in the video. I plan to build something rigid for show! However I got results that made me want to invest more time and effort with how I approached the testing. Go build your own boat. I'm sure I could criticize it as well.
Don't presume to speak for all the people that are looking at this. They may well be interested. I posted what I did and saw. All the info is available on this thread tfor whomever may want to try of what I have done.
Talk about raining on a parade.
Thanks!
ds yin/yang
