Magnetic spinner magnet motor on youtube
Started by hartiberlin, June 04, 2007, 07:12:04 PM
ltseung888
The next experimental steps from Sun et al:
Sun et al are now working on the Pulsing Mechanism using electrical means.  See the two videos on youtube:
pulse Motor vertical http://www.youtube.com/watch?v=BX0hoiVnrxA
pulse motor horizontal http://www.youtube.com/watch?v=CT9EPYHDjDg
With electrical input energy, both wheels will rotate forever or until the parts fall apart.  The following are suggested:
(1) Determine the minimum input energy to rotate the wheels.
(2) Determine the effect of multiple input coils; the pulsing strength and the Pulsing rate.
(3) Experiment with a separate electricity pickup coil (This works in the reverse principle of the pulsing coil.)
(4) Experiment with the Pulsing Coil acting also as the pickup coil. (Similar to the Bedini or Joseph Newman machines.)
(5) Experiment with using the axle as the power source. (Similar to the 225 HP Pulse motor.)
Sun et al are planning to sell 'platform' toys for the experimental developers and budding scientists.  You can look forward to having perpetual motion DIY toys that do not violate the Law of Conservation of Energy on your desk in the near futue.  You will have fun playing with them.
ltseung888
Quote from: TheOne on July 03, 2007, 07:00:43 PM
i am not phisicists, i just want to replicate it and i need simple answer like what are the orientation of the stator magnet and what are the orientation of the rotor magnet?
Sun et al are still experimenting with different magnets, different orientations, different angles etc.  That is the reason for the magnets wrapped on water bottles.  The answer is far from simple.
If you are impatient and want to experiment now, look at the video carefully.  Do something similar.  Dozens of people have successfully achieved the same result.  Note that Sun et al did not achieve perpetual motion with this setup.  It rotated for 30 minutes only.
If you do not mind waiting, you can purchase a DIY platform toy from Sun et al when it is ready.  I cannot give you a firm date now.  Keep reading information from this forum from time to time.
TheOne
That will depend how they cost :)
I say that because I have like 100 neo magnet (smaller then the one you are using)
but i have it but don't know what to do with it lol
I dont really need to know exactly all the setup but what i would like to know is more are the rotor magnet are facing all in the same direction and same for the stator
Freezer
Quote from: TheOne on July 03, 2007, 05:21:32 PM
as far as I can tell the wheel turn a more then 360 you know?
I was talking about the op's video.
I'm sure that wheel ltseung888 posted should work.  I dont think its good enough for a generator, but good enough to turn itself for a while.  Perhaps they should try using that new coil design with no back emf to build up a charge.
TheOne
Quote from: ltseung888 on July 03, 2007, 09:16:35 PM
I have another question, the wheel need a lot of magnet for the stator to make it turn? you cannot do it only with one magnet as stator and the rest in the rotor?
