Chas Campbell free power motor
Started by TheOne, June 04, 2007, 10:25:17 PM
d3adp00l
So ash just to clarify, does this thing run on ac and produce dc? or does it run on ac and produce ac?
History is full of people who out of fear,
Or ignorance, or lust for power have
destroyed knowledge of immeasurable
value which truly belongs to us all.
WE must not let it happen again.
-Carl Sagan
ashtweth_nihilisti
Okay just to clarify, Chas runs an 800 watt induciton motor form the 50 hertz AC mains, to this he is driving(via his gravity/flywheels) a 3.5kva alternator, (AC in, and AC out)
So already to get power out of a 3500 watt alternator you need at least 2 HP? maybe more, so already is OU. His motor is aobut 3/4 HP. As we want to silence and educate the skeptics , we opted to go DC in and DC out.
we can produce a DC reading via an inverter, and also rectify the AC into DC at the alternator out put. Simple as saying OU.
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
d3adp00l
I think simple ac clamp meters would be much much easier. heck just pull a couple watthour meters from a savage yard. But anyway you want to do it, go for it. For ease sake 746 watts=1 hp, soo 800/746= 1.07 or after heat loses 1 hp. 3500 watts (mind you thats only if you are using 3500watts, just turning the alternator takes almost nothing) 3500/746=4.69 hp or 4.5hp after loses. Or a total possible of 450% ou at a maintained max output, must be maintained, not just a momentum storage energy of moving mass. Good luck ash.
-Carl Sagan
ashtweth_nihilisti
Thanks man, we need that sort of data to put on the video.  Sure i have a fancy digital AC meter which we can compare to the DC readings too :)
At least we know with DC there is no voltage phase angle and power factor stuff ;D
Joh70
"Chas runs an 800 watt induciton motor form the 50 hertz AC mains" Means that, the unit consumes conventional electricity from net to run? If yes, this looks not so elegant to me, although it's possible that it's overunity. An autarc/isolated system which also runs in Africa's desert to serve a water pump, would be better - like a real "bessler wheel" has to be able to do mechanically. What when electricity is shut down?
