Chas Campbell free power motor
Started by TheOne, June 04, 2007, 10:25:17 PM
ashtweth_nihilisti
Quote from: wattsup on August 31, 2007, 11:18:19 AM
Well my home internet connection is down again. Can only use at the office.
@DingusMungus
That software you talked about. Went on the site. They are asking $5000 dollars for a single liscence. Are they dreaming or am I mistaken.
WMD is on emule  ;)
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
hartiberlin
Welcome back Ash,
when will you post your report ?
Many thanks.
Regards, Stefan.
ashtweth_nihilisti
Hi Guys, am soo sorry to be in late :-\, i had had an influx of people ringing and Inquiries, plus still have the non profit org to maintain. And my mobile phone sux!!
Thanks to Laurence, Hum and Stefan and ALL!. This has helped, and is why we need a Granted research and development center!! http://www.panacea-bocaf.org/ResearchandDevelopment.htm
I will add all this into the Chas Video presentation, so we can help educate the world and faculties. We will be AT a university soon with our Water fuel cell (Ravi/Daves replication).I will be presenting allot of research in support of you guys. http://www.panacea-bocaf.org/RandDprinciples.htm
Now...what an inspiring day, First i must mention Chas is true to his word and wanted independent replication and just grant support. Chas never stated he could load his devices and maintain the proper tuning. He still wants to improve and wants you all to build his perpetual Wheel and or improve his motor/Gen/flywheel system, he is still looking to get some grant endorsement to build a better system. His ideas are sound.We will prepare this for him in the video presentation.
Chas also understood, that to be a 'marketing genius' or for disclosure you have to allow INDEPENDENT REPLICATION OF THE DEVICE, then it becomes science. If you claim OU, you propose the theory and device, you then let people (if your not open sourced -under non disclosure) reproduce your results, Then it becomes science, live and learn Steorn.
Just to clarify what Stefan said, the duty cycle is important!, so is pulsing gravity devices.
http://www.panacea-bocaf.org/VeljkoMilkovic.htm
http://www.panacea-bocaf.org/WangShumHo.htm
http://www.overunity.com/index.php?action=dlattach;topic=203.0;attach=9173
http://www.overunity.com/index.php/topic,203.45.html
The RV was pulsed with a prony Break, and for 500 watts gave out 1HP
@Hum, please prony break the RV, a man as vigorous as you can find out that centrifugal force and pulsing needs more experimentation and understanding by us.
"Doug Konzen?s prony Break testing
For the third time I tested the 7.5hp Baldor motor with the series adding wiring which
gives 5.9 ohms resistance to each phase. This time I tore the motor all the way down
first, photographed the internal wiring and labels, and also oiled the bearings just a bit
with some "Kroil" brand hi-tech lubricant.
The phases are wired in Y fashion - and the motor is run in Hector's roto vertor-mode
with a 7UF run cap across lines 2 and 3. At 1650rpm no-load idle, the motor draws
.3Aac @ 120Vac with the 7UF cap.
Any amount of force from the prony brake that exceeds approx 80 ounces on the scale
with the corresponding amps input of approx 2.3Aac will bring the motor to a stop.
In this testing, and the previous too, it has been found that this particular RV'd 3ph
7.5hp Baldor AC motor only likes just a couple narrow "notches" of speed and torque
being squeezed from the shaft by the foot-long Teflon-collar prony brake.
And as before in the two earlier test-runs done this week, it was possible to keep a
consistent force of 54 ounces (3.375LBFT) on the scale, which corresponds to a
simultaneous reading of 1 Aac @ 120Vac input to the motor showing on the meters.
And also a force of 43 ounces (2.687LBFT) and the simultaneous .8 Aac @ 120Vac
input to motor on the meters was another narrow notch-of-power from the shaft to
extract.
So again, it is almost a full HP (746watts) of shaft-power from under 120 watts
electrical input, and still haven?t tried out more UF values to the run-cap in order to
fine-tune it to the load.
RESULTS:
1/20/2007
120VAc grid-power input
7.5HP Baldor motor
.81 power-factor rated showing on label (stock rating)
88% efficiency rating on label (stock rating)
7UF run-cap used in both tests
Test #1:
.8Aac X 120Vac = 96watts input
2.687 LBFT X 1550rpm / 5250 = .793HP X 746 = 591 watts output
Test #2:
1Aac X 120Vac = 120watts input
3.375 LBFT X 1500rpm /5250 = .96HP X 746 = 716watts output"
End
At first we connected two 500 watt restive load lights, and it de tuned the system exactly like Chas said it should. All this pointed to the energy being stored in the fly wheel. After two of my engineers had to leave, i had an idea to pulse the load out based on my research with panacea, mainly konesheads proney break test.
We connected two AC amp meters, on on the drive motor, and one on the alternator where the load went through. You will see on the video, Chas and i pulsed out the power tools, a drop saw and a hand saw, we also put it under load as you will see on the video.
The figure on the video shows the tools drew 10 amps when pulsed on and off in 2-3 seconds, (prob more like 2) The input remained steady on 6 amps. This was for about 5 minutes constant. We will conduct more tests and will conduct what ever you all  request. We will be attaching the RV which i predict will take the input down to 3 amps/10 amps pulsed out 1-2 seconds all at 240 volts. We can also Gear it down and freq drive the fly wheel from the RV. http://video.google.com.au/videoplay?docid=9089608413203959523
@hum
Alt is 240 volts
Now, Before any one passes judgment and or gets excited.Chas has built a perpetual wheel, the big one you see  in the video has been made to spin just using gravity, using snooker balls and Chas wants you all to improve and build the system, ill be sending it to Patrick Kelly to write up.
He explains the system himself via diagram and we show you how the wheel spins, he proved the concept by using 3 balls which made the wheel continuous and should it would go onto do what he said it would if the balls were constantly cycling.
He could not build it as robust as he wanted, so it vibrates and makes the balls fall off and de tune his wheel, he has had to use very primitive materials (TIN), he needs better materials/grants etcs. You will see this is amazing on what he had to build, and you can see on the video that if the big wheel didn't wobble the balls would consistently cycle and turn the wheel!!
Guys please be patient for the video and PM wheel instructions, we have allot to edit and present, my partner had to goto Sydney for the week and is editing now, ill give you the ratio's of his motor gen flywheel system, as he wanted, we will above to wait for the perpetual wheel instructions till we finish the edits please be patient  ;D.
Conclusion, more is needed to be done to assess and provide a better presentation. This will be done, on the 15th of Sep.
RV drive motor will be added to cut the Crappy 6 amp draw down to 3 amps
Duty cycle will be more vigorous for Stefan
FET IGBT pulsed circuit into a load will be constructed
Freq driven RV test will be done
On his perpetual wheel
conclusion IT WORKS!!! Chas's expertise is in Gravity wheels so far, his ideas remain plausible based on his understanding of how his system preforms, he never claimed any thing which wasn't going on.
Chas's spirit was to give this away, his heart is in the right place and he should be supported [Granted] and encouraged here are his ratio's till we get the edits done
He is also on video explaining these for you guys. Editing will be done soon
On Behalf of Panacea-bocaf and OU forum, i would personally like to thank Chas for his altruism.
More to come...
Drive motor-1430
motor speed 1430rpm pulley -2.75inches to 5.5inches
cuts the speed of the motor in half.
then 5 inch pulley
8 inch pulley
4 inch pulley
9 inch pulley
4.5 inch pulley-> ALT 3146 watts 240 volt 50 hertz.
fly wheel 72 inch thick
12 mil custom
6 lay
10-20 kilos
Guys you have to wait till the video is done to see the new set up and apply these raitos, THIS IS NOT THE OLD SET UP
This does the same as the old set up but is the simplified set up.
hartiberlin
Hi Ash,
many thanks for this first report.
Looking forward to see the videos.
Maybe the big Bessler like wheel with the snooker
balls will be easier to build for the first time than the flywheel
motor-generator system.
So try to get the Bessler wheel video first out.
Many thanks again to Chas for make it publically availble.
Many thanks again.
Regards, Stefan.
GraViTaR
Please put me on the list of people who want to learn more about the gravity wheel.
You're doing a great job, Ash!
