Chas Campbell free power motor
Started by TheOne, June 04, 2007, 10:25:17 PM
ashtweth_nihilisti
Hi Lawrence and all,
Thank you Lawrence we will be attaching that to our presentation of this system, depsite Chas not have a refined system and or a working system ATM, there are still many themes and benefits we can attain from this whole experience, and that data you provided needs to make it to the light and day so does all the other gravity theorems/devices mentioned so far and the response Chas got. Plus How you and Chas need endorsement and investigation /support.
This is what we will be putting into a presentation i order to help the public and faculties 'catch up'
Our production which will have further testing results (we will still post only the results on the board later)
BTW for tinkers here are some private email is got on the subject.
"Hi Ash,
I do not think this system works. There cannot be a simple thing that
hasn't be thought to before. What does the physics say about it?
Lets approximate - outer ring is 2x bigger than the inner.
Thus to raise the ball up takes 2x times longer, that makes the system
energy balanced.
Momentum x time = energy: down = M x R x t
Momentum x time = energy: up   = M x r x 2t = M x R/2 x 2t = M x R x t
Did he show a solid proof that the ball that went down, came up again by
its own momentum without the rotor being touched?
It can only work when there is some rotational gravitational effect or
anomaly.
H: OU is transformation. Energy must come from somewhere. Gravity is not
an energy. Earth rotational momentum is the energy that can be tapped but
by normal physics it is very tiny (using big and fast gyros)."
Answer
"wrong...
To raise the ball with inner radius takes exactly the same amount of
time than to drop a ball with outer radius as the wheel is uniform and
all parts of the wheel are moving in synchronicity.
Also, he talked about the experiment with ball and aluminium profile:
if you put a profile's one end to ground and lift the other end few
inches and then put the ball on this elevated end, the ball starts to
roll down the slope and accelerate. He said, that at certain distance
the ball has enough energy, that when it's course is directed properly,
it can come up to the initial level again... (or something like that I
understood).
It is actually quite logical:
1. energy required to lift the ball directly up to certain height Ep=m*g*h
2. now we need to calculate the ball's kinetic energy on the slope at
certain distance from the beginning (hmm, need to dig some old physics
book in order to calculate that). The trick is, that the kinetic energy
grows with the square of velocity, so at certain distance from the
slope's beginning the ball's speed should be sufficient and the
Ek=(m*v*v)/2 should overcome the Ep=m*g*h (the square always grows
faster than the simple multiplication) and we can direct the ball
upwards with certain means and voila... Hehe, hopefully I'm not grossly
mistaken here...
Also, if you take into account the law of conservation of momentum,
things might get even more interesting.
An experiment: sit on a rotatable chair, take two beer sixpacks, one to
your each hand and strech/lift the arms to the side so that you are now
holding the sixpacks 90 deg from your body. Let your wife to rotate you
(or get the cair to rotate with your legs), when you keep the sixpacks
at the same position (now you and streched sixpacks are all rotating
with the chair). Now, while rotating, try to pull the sixpacks towards
your body. Uhh, what happens??? Your rotation speeds up considerably...
Now think about the ball, that has come down some slope and has
considerable kinetic energy. It is always said, that the best way to
utilize such energy is to transform it maximally smoothly (a la tesla
turbine with fluids moving in spiral from perimeter to center opening).
Do the same thing with your ball - direct it onto a circular track, that
is built like cone. At the base the radius should be big and when the
track now rises, the radius should also get smaller and smaller all the
time (the change might not be linear...). Now the ball, as it rises on
the track, is further accelerated by this same conservation of momentum
law and should rise more easily...
This is just an idea and needs to be checked out with suitably rigid
tube and nice heavy steel balls."
Answer two
"what you are saying has much merit.
There are more forces and actions going on, where a person needs to look at the full picture.
Not only is there a lever action from the balls pulling the wheel around, BUT these have also gained kinetic energy where if they were to slip off, or I should say be released from the wheel they would fly out with velocity.!
The balls are not just dead weights. There weight is used to cause rotation but at the same time there is energy now stored in there mass from centrifugal force.
So from my perspective, I can see that we use gravity which is an ever increasing acceleration to create work, then at the right time using the energy stored in this mass to bring it back to the beginning of the cycle, all makes sense.
Put it this way.
What goes up must come down. So lets say we drop a ball from 10feet high, well it falls down and then bounces back up say 9feet.
Now think about this, where the ball drops 10feet but we tapped into this to create work, well that's great but don't forget we have also put the ball now into a centrifugal force at the same time.
What I am trying to say is this effect is the same thing where they fling satellites around planets, to gain kinetic energy for greater acceleration.
http://www.astrosociety.org/education/publications/tnl/34/space3.html
Maybe my imagination is way out there, but I am able to visualize gravity forces in conjunction with centrifugal forces where it must be possible to use gravity for one part of the cycle but use the generated centrifugal force for the net gains.
I mean if all was perfect and the energy gained as the ball drops was the same energy needed to take it back to the top again was needed,,, hey what about the fact we made this ball fall through a swing so it gained a bonus centrifugal force for free?"
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
Humbugger
Quote from: ashtweth_nihilisti on September 07, 2007, 09:19:30 AM
HI Jim the video is PUBLIC knowledge feel free to upload it to where ever, i couldn't upload to google video as it times out ???
We will soon be uploading our water fuel cell replication and self running neon switching RV demosall open sourced [plans and videos]
I guess I must be the only one who noticed this.  You have a self-running RV?  Holy Moses man!  Why in the world would you be fooling around with gravity wheels that don't quite work and non self-runner electrical machines that bog down if you have a self-running RV?  You should focus on what works!
HEY!  EVERYBODY!  ASHTWETH HAS QUIETLY ANNOUNCED HE HAS A SELF-RUNNING RV SYSTEM!  GATHER ROUND!  HE'S UPLOADING THE PLANS AND VIDEO SOON!
How much free energy does it produce?  Wow!  You are the master of understatement, dude!   I never knew you had a working self-runner!  What a surprise!  You must now disclose all the details of course.  I want to build a nice big one immediately!
Humbugger
ashtweth_nihilisti
Just to clarify for the Board as Hum you all know is talking to him self from now on when addressing me.
The self running Neon circuit has been reported by David Kou in France as working and is on the RV page, we have replicated the circuit and will be testing it on our RV next week. Attached is the circuit for those interested in it.
Humbugger
Quote from: ashtweth_nihilisti on September 08, 2007, 09:35:50 PM
Is he saying that someone in France has reportedly put together a working self-runner energy-producing system (where are the videos and reports on that?) or is it just some new electronic circuit that "works" which he and others are hoping might make self-running possible?  I can never quite tell what is really being said except when Ashtweth is hurling insults and accusing skeptics of being "oil men".
I assume it's just another hopeful magic circuit but it sure seems that efforts are being consciously made to make it sound like self-running has been achieved.  I keep hearing claims, or what surely sound like claims, of self-running RV setups by Hector and this Kou fellow and these are reported to be folks who Ashtweth works with very closely and has for quite some time.
Why have we seen no video demonstration about these astonishing reports of self-running machines?  Wouldn't that be far more worthy of Ashtweth's time than chasing after gravity wheels that don't turn and non-self-runners that can't stand a steady load for ten seconds?  To be accused of wasting Ashtweth's time, which I have been on several recent occasions, seems rather unjustified in light of all this.
I prefer my information about major world-shaking scientific developments to be stated in unambiguous terms so that I know what is actually being said.
Humbugger
b0rg13
hi all , first of all please excuse my very bad edit of some one elses pic, but would this work ?.
if you want to get out of the rat race,you have to let go of the cheese.
