Chas Campbell free power motor
Started by TheOne, June 04, 2007, 10:25:17 PM
markdansie
I agree with request for watt meters, Also the test has to run over a period of time to eliminate the actions of flywheels storing energy comming into play.
I am still perplexed why I am not allowed to attend on behalf of the NEC which has a great reputation in these areas.
I have to fly out of Australia in a couple of weeks working on other technologies, but am available up until then.
Mark
ashtweth_nihilisti
Hi Mark,
You would be more then welcome to attend, we are getting help by others who have watt hour meters for the board. So no need ATM to come and see what can be done any ways, these are trade professional Watt hour meters and can tell you every thing you need to know.
So far AS IS all signs have pointed to it being a mechanical flywheel storage system,  However we are going to do some pulse tests based on Lawrence's advice and others.
Even after every one closes the book on his set up we are still going to do ALT extraction stuff and pulsed duty cycle tests. So at least the board has an R and D tool to play with. If more then interesting results are observed you are more then welcome upon approval from Chas to come in and check for magic hamsters or poor measuring technique.
Have a safe trip mate.
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
ltseung888
Quote from: ashtweth_nihilisti on September 12, 2007, 10:42:47 PM
Dear Ash,
I shall repeat my latest recommendation for your coming trip here.
(1) The schematic diagram (Thanks to Hans von Lieven and Patrick Kelly from Panacea) with actual dimensions is excellent and appears easy.  We plan to replicate it in China.
(2) We should be able to get same or similar A.C. motors and alternators in China.  Some tuning may be needed.
(3) Gradually increase the load.  Accept that we might have to vary the tension of the belts on different loads.  Turning on ten 100 watt bulbs is better than turning on one 1,000 watt bulb.  Please keep the rotational speed as high as you can.
(4) If we perfected the auto-adjustment mechanism in (3), I believe we essentially have the Tsing Hua University Electricity Magnifier in wheel form.
(5) The Tsing Hua University Electricity Magnifier is NOT only an energy storage system.  It is also an energy Lead Out system.
Best of Everything in your coming meeting.
Lawrence
ashtweth_nihilisti
Hi Lawrence,
Personally i would like to thank you and so does the trustees and volunteers at Panacea for your ideas and enthusiasm /support. Patrick Kelly has added your thesis to our on line university, also your page and Chas has been updated with your document. The new site is being uploaded now.
We will be presenting a Full video production of all gravity devices which are currently reported working, Bob mays, Milkovics, and presenting your Gen and thesis with the experimental data we attain at Chas's test.
We will also be getting faculties and government to go on record stating they have evaluated this research.
We will also be presenting this along with our water fuel cell and neon switcher to the public in order to attain support for all open sourced engineers and work towards getting a RESEARCH AND DEVELOPMENT CENTER.
Check got it Lawrence, will do those tests for you.
The video will take time to edit, how ever we will be posting the pulse RV tests parts here exclusive for Stefan, so you guys don't have to wait  ;) wish us luck Guys, plenty more to come.
sm0ky2
@ Hans
   i have never heared Milkovic claim perpetual motion from any of his devices. He claims USABLE energy from the LEVERAGE. i have however seen  MANY OTHER PEOPLE who see his device, claim that it is OU, when it is not.
There is nothing OU about the Milkovic device.
It usilizes the well known forces of a pendulum to activate a leverage, incidently at the exact moment when the force is at its maximum. (bottom dead center)
this force can be calculated for any pendulum, and with the known distance of the lever you can calculate not only the ammount of applied force on the other end of the lever, but also the exact number of swings the pendulum will endure before comming to a complete stop. (if not pushed again)
Also to be noted is the there is a range at which the ratio of the lever, andthe mass on either ends (mass of pendulum and mass of "hammer" or weight applied to the opposite end of the lever).
if the mass on the hammer end is too small the pendulum end will always be in the down position, if it is too great for the mass of the pendulum + downward vertical force-pulses to counter, then the pendulum side will always stay in the up position. - If you calculate various mass/lever combinations within this range you will find that the energy exerted on the hammer end (added up for each pendulum swing) is exactly equal to the force input to make the pendulum start swinging.
Furthermore: If you count the number of swings of the pendulum between pulses (or kicks) needed to keep it moving, and divide the energy of each pulse by this number it will be equal to the energy output on the hammer end. (we are talking energy not force).
The laws of physics still apply when it comes to the Milkovic water pump.
If anyone has a descrepancy they would like to adress here i a more than willing to hear you out.
I am not a critic of perpetual motion devices, but i have spent a good majority of my life in seek of one.
The Milkovic device is not it.
