Chas Campbell free power motor
Started by TheOne, June 04, 2007, 10:25:17 PM
hartiberlin
Okay, just let us all have some patience,
until all the data is in, which is not yet.
So please don?t make up your mind yet, until
we have the new measurements via the RV setup.
This way we can also see, how good this RV drive setup really is.
I hope this time a real good measurement is done which will
be also documented via video.
I am also looking forward to see some videos of this RV setup
charging back the batteries via this neo switcher circuit.
It takes time to compile the data on these measurements
and make a videocompilation to document it all.
So as these RV researchers probably are still working on
their fine tuning, they did not yet have time to make
the right documention yet.
So please give them some time and be patient
and do in the meantime your own experiments
with your own favourite OU toys...
Many thanks.
Regards, Stefan.
ltseung888
Quote from: RoadRunner on September 16, 2007, 05:53:25 PM
Quote from: gaby de wilde on September 16, 2007, 04:45:12 PM
A pendulum swings much faster if you stick a magnet under it. Do you have an idea why this would be any different for flywheels?
In a word, magnetic flux gradient.
Okay... That's three words !
A pendulum is not balanced. It is, by its very nature, an unbalanced system.
If you had an unbalanced flywheel it would operate much the same way as a pendulum but then it wouldn't really be a flywheel, would it ?
A pendulum would swing faster in a higher gravity environment and slower in a low gravity environment (that's the results of a quick thought experiment, not something that I can quote as a known fact, however, I think you'll find that it is true, especially if a magnet below a ferrous pendulum makes it swing faster).
The same is not true of a flywheel because of balance.
A pendulum converts PE to KE on the downswing and KE to PE on the upswing.
Again, the same is not true of a flywheel unless it is unbalanced and oscillating like a pendulum.
The RoadRunner..
Dear RoadRunner,
Ms. Forever Yuen did the magnetic pendulum experiment which could be repeated readily.  If the Pendulum bob were replaced by a magnet, the oscillation time will be faster if the magnet underneath attracts the Magnetic Bob.  (or more oscillations per minute).
If the Manget underneath repels the Magnetic Bob, the oscillation time be slower (or less oscillations per minute).
You are right in saying that an unbalanced flywheel behaves like a pendulum.  The uneven rotation is equivalent to pulsing.  This Pulsing Leads Out gravitational energy!
Lawrence Tseung
Pulsing of an unbalanced flywheel or cylinder Leads Out gravitational energy.
markdansie
Iear Stephan,
I am shocked and horrified at Humbuggers removal. There has been no evidence what so ever that the claims that Chas has made have been repeatable or supported by any evidence presented to date.
Humbugger may have lacked diplomicy, however he was experssing the views of the silent majority. I spend my professional life travelling the world, testing OU and other claims and I feel Humbugger brought logical arguments and sensible suggestions of how to test the claims of this device. All I have seen from you and a couple of others, is how to bend the data to suit the result you want to see,,,rather than analysing the data objectively.
This has done your credability a lot of damage.
I openly support and encourage people like Chas to continue their work...however one must always be honest firstly with themselves, and others. Without data being repeatable of independently confirmed..it is of no value.
I am involved in two projects now..one is a self running magnetic motor and the other is emissions and fuel economy technology. Before going public these projects and the people involved are testing, checking data and above all making sure their information is correct, repeatable and validated independently. I grow tired of seeing the endless promotion of claims in forums like this...only to be dissapointed because more emphasis was placed on the sensationalism rather than the facts. Look at the endless list of projects here...none have collected your prize and none have had any value in solving the worlds energy crisis.
However the site is useful for encouraging people to share info, inspire others and introduce people of similar interests.
The freedom of speach, logic must always be defended. Your type of censorship shows bias and scares the hell out of me.
I was censored by you over 12 months ago just for asking questions (in a polite way) in another topic. Please re-enstae Humbugger.
I await paitiently for the latest results and video....I will hoopefully fill up the void created by humbuggers absence and give an objective, unbiased view of what is presented, using scientific principles and logic.
Kind Regards
Mark
hansvonlieven
G'day all,
Quote from: ltseung888 on September 16, 2007, 08:53:30 PM
Dear RoadRunner,
Lawrence Tseung
You are talking rubbish again Lawrence.
A magnet placed under a ferrous pendulum bob will take energy out of the bob whether in attracting or repelling mode. It will not slow down the rate of oscillation as the frequency is determined by the length of the pendulum, nothing else. It will however shorten the length of swing.
As to gravitational energy being "Lead Out" of the system in an oscillating mass that is utter crap.
Why don't you make a pendulum and observe what it does instead of pontificating this sort of nonsense.
I think you post this stuff only to make fun of people and I think this time you gave yourself away  "Ms. Forever Yuen" ? Are you for real. Last time I checked Ms Forever was aging rapidly!
Hans von Lieven
sm0ky2
here it is monday, and no word from Ash?
