I.T.E.R., a need ?
Started by lancaIV, June 08, 2007, 06:49:42 AM
Visit rexresearch and inform yourself about " Oleg Gritskevitsch et al." :
1500 KW Generator !
1% input !
Functional !
500 US$/KW !
0,001 US$/KWH !
Clean process !
Is Russia not an I.T.E.R.-project partner ? Why ?
Sincerely
            de Lan?a
ashtweth_nihilisti
Is this the T.O.K.A.M.A.K -I.T.E.R ? if it is, is in direct competition with Focus -Fusion which was suppressed as a result.
http://www.panacea-bocaf.org/FocusFusion1.htm
http://www.panacea-bocaf.org/FocusFusion.htm
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
helmut
Quote from: lancaIV on June 08, 2007, 06:49:42 AM
1500 KW Generator !
1% input !
Functional !
500 US$/KW !
0,001 US$/KWH !
Clean process !
Sincerely
            de Lan?a
Thanx for the advice.
Does someone replikate it?
helmut
No, it is not the T.O.K.A.M.A.K.-I.T.E.R .,
but a simpler construction for the same internal nuclear process !
Yes, there are several commercial groups, who want to realize the "-TRON" -Technology,
also  electronpowersystems.com   (eps), beside Focus-Fusion !
They,eps, write about the possibility  to bring down the KW- plant price to 60 US$,
this can be realized  if the Gritskevitsch numbers, 900 KG for 1500 KW, are real !
If the material is not special,like that of ordinary ic-gen-sets , then we can use the common
price of "home-depot"-ic-gen-sets, in Europe 10 Euros/KG !
Gritskevitsch wrote in his publication about low temperature-process  !
900 KG X 10 Euros= nice price: 9000 EUROS : 1500 KG = 6 EUROS/KW
What is the weight of a  800 hp/ 600 KW F1-motor( TOYOTA,RENAULT,HONDA,...) ?
S
  dL
helmut
Quote from: lancaIV on October 05, 2007, 11:34:57 AM
S
  dL
Hab mal nachgeschlagen.....Zitat:
Das Motorgewicht
Motorgewicht und Verbrauch sind extrem wichtige Parameter f?r Formel 1 Fahrzeuge.
3 Liter Saugmotoren :
8 Zylinder   ~100-120 kg
10 Zylinder  ~100-130 kg
12 Zylinder  ~120-140 kg
Neben dem Gewicht des Motors ist seine Steifigkeit von entscheidender Bedeutung. Der Motor verbindet den Hinterwagen
bla bla bla...
gew?hlt, da? sich f?r den Zw?lfzylindermotor eine Leistung  von 530 kW ergibt. Nach der Theorie d?rfte dann der Zehnzylinder nur noch 497 kW, ein Achtzylinder gar nur noch 462 kW haben. Das entspr?che einer Minderleistung von 6 bzw. 13 Prozent. In der Praxis hingegen ist die Leistungs?berlegenheit des Zw?lfzylinders gegen?ber einem Zehnzylinder oder Achtzylinder sehr viel geringer.
S
helmut
