Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
BEP
Build an OU device? Since OU doesn't exist you know my answer.
The comment was a responce to observations. Observations of posts that appear to be going in the right direction.
Motorcoach1
@ Ronnett - 2 things I have done in the past is melting dentist wax in a tub and rolling the cone in it to coat. the other was sandblasting stincel the liquid type made by 3M , it brushes on. I'm working on useing a copper ball and accustiocle couple the wire end if the coil to it as a floating ground. The last few weeks I have been studying hurricanes and tornatoes to find some electrical effects in the vortexes. I feel this is as close to nature as I can get to make an operational unit. I have found some very interesting things that can't be seen in a smaller unit, so after I put together a plan then scale it down. What got me on to this was some guys had cool air comeing from their coils and found that if the negative CW vortex is not staerd first then it won't start at all.It's easy to get the CCW going because that is a natural operation in the northren hemisphere. so don't abandon those old coils yet.
Jdo300
Hi Motorcoach,
Now that is a breath of fresh air (no pun intended) to hear! The secret to the TPU is the rotating field!!! no rotation, no output. Simple!
In case you are all wondering what I've been up to, I'm currently designing a precision DDS control circuit that will give me the ability to produce the rotating fields in my coils all the way up to 50MHz. What I now know is that the rotating field is primarily a rotating potential field with a minor magnetic component associated with it; basically a longitudinal field. Once this field starts to rotate, you have to do something to it to form it into a vortex. This is accomplished by adding an orthogonal DC bias to the coil to add the third dimension to this field. Once the funnel forms, then you have created the mechanism by which energy can be extracted from the environment. If you make a plot of the electric field lines in the vortex, it becomes immediately obvious why the collector coils outputs DC. To increase the effective aperture of this vortex, add a high voltage electrostatic bias to the coil. Now the vortex will modulate this bias field to help entrain (and control) the incoming energy.
So to simplify this. The simple recipe for a TPU is this:
1. A rotating potential field
2. An orthogonal magnetic bias
3. A high voltage electrostatic bias.
These are the three principles that I see cropping up time and time again from not only the TPU but other weird devices that exhibit the same effects (mostly in the anti-gravirty research area). So yes, I agree with you, we need to be spending more time making rotating vortex fields to really see what this thing can do.
God Bless,
Jason O
ronotte
@Jason,
at the end you are still here...glad to hear from you.
I mostly agree with what you are saying but.........remember: SM did it almost without any electronics so we are speaking about coils, air and some magnets: that's all. I fear that if we seek the hi-tech way we are going out of the context. I do confirm AS I HAVE ALREADY TESTED IT that using a DC high voltage bias does produce increase in the output (about 4-8%). In my case actually it sufficed a voltage of about 60V...increasing that voltage up to 500V did not produced any more output. I did it just rectifying the ECD output itself and putting it onto an annular aluminum plate fitted under the ECD. Same effect is obtained by just polarizing a secondary winding in the control coils.
I wonder if BB project is successfull as it will be great!  Probably you are building on DDS just to control it. GOOD LUCK!
Roberto
ronotte
Hi all
@Motorcoach,
I tend reasoning like you, I did it since more than1 year ag? so you may think I did not tried as many of us?   Of course I did it and IN MANY WAYS:
- firstly  by using the Tesla pat approach,
- then by selecting freqs as 1st, 2nd and 3rd harmonics,
- then by using asynchronous and synchronous harmonics,
- then by using 2 contro-rotating fields in the Tesla approach,
- then by exciting the coils in sequence with a shift register at various freqs,
- then by using a set of harmonics auto-rotating in phase,
What the best method?  It has been almost all written down in my many posts without any secret....do you think I've to cancel them?
Of course a lot of work but it let me gain as well a lot of knowledge as I BUILD MYSELF ALL.  It has been fun for me, a way to use for a target my free time.
NO OU?   it's true but nobody for the moment get at it using only coils, air and a bit of electronics.  Some time I saw something really OU...but never been able to duplicate/understand it.
YES I had for almost a day an auto-sustaining TPU operating without any oscillator: just delivering power....not much. That's the reason why I'm still working.
Best regards to all
Roberto
