Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
otto
Hello all,
@Roberto
why didnt you continue to work on your auto sustaining TPU???
Otto
ronotte
@Otto,
of course for some time I did it...then I get tired as found NO WAY to duplicate it!  Still now I don't understand how it happened.
Roberto
otto
Hello all,
@Roberto
in the past you did a lot and a great work!! But you, myself and a lot of people here used "oridinary" coils. Im talking about the collectors. In that time, over a year ago, we didnt know about the Mobius.
If the Mobius is connected - closed - then you have a  rotation of the "tornado", of course with some signals on the controls.
I have to warn all of you: if you have a Mobius as collectors you MUST have a REED RELAY inside your TPU because this Mobius works ALL THE TIME, if started. IF the signals are self amplifying then, without the reed relays you will be in trouble. You cant just switch OFF the Mobius, no way.
Why do you all want to understand everything? OK, Im not so good educated as you are but I saw a lot of theories....just build, enjoy and when you have results then try to explain whats going on in your coils.
For now Im using oridinary controls wound all over....in segments. They are not soooo hot like the ECD coils and thats great. Of course, I have to see whats the best lenght ....Im also waiting for my tubes....
Otto
BEP
When I say OU doesn't exist I mean it. The energy is coming from somewhere. It isn't being created. It is only being converted. And Yes! it is there.
Cavemen could have called fire OU. I'm still banging rocks together and I'll continue until the fire starts!
@Jdo300
At any point did you happen to include a capacitive base for the top and bottom coil with all the other things you accomplished? The two plates then become a capacitor as load output.
BEP
I'll continue the thought as it is the direction I'm taking:
Once the capacitive plates or rings are installed and the Mobius is flipped at the crossing point you are applying opposite polarity fields to those plates. What happens when you apply a field to a plate? It tends to collect a charge of opposite polarity. Drain some off to continue the effect? Like in a lamp?
I doubt this would be impressive unless you are doing it with the vortex.
Just thinking out loud again. It is almost time for my medication  ;D
Oh yea. Heating will likley be a problem and I suspect the mechanical vibration will be from the entrainment and magnetostriction.
I still believe the controls must be completely inside the TPU.
Sorry, medication hasn't taken effect yet.
