Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
Grumpy
JUST BUILD IT!!!
...then you can answer your own questions.
        -Frank Edwards
gn0stik
Quote from: duff on June 13, 2007, 03:05:03 PM
I'd like to suggest that after the next replication is accomplished with square waves, you inject sine waves, and perhaps re-tune to verify the effect still exists.
Perhaps the square waves and related harmonics are responsible for most of the harmful effects that have been reported and this is why SM stressed pure sine waves. I realize everyone is very aware of the possibility but I have not heard anyone state it.
-Duff
Not a bad idea, however I have to point out that SM never clearly state that he was talking about pure sine waves, we assume that because of the context. He could mean very very accurate pulses.
My gut tells me that we wouldn't see anything with AC input.
Bruce_TPU
@ Duff
SM said "Pure frequency", not "Pure Sine wave".  I made that same false assumption in my thread, until re reading SM's words.
Cheers,
Bruce
