Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
libra_spirit
Attached is my diagram showing the platonic resonance overlay.
Dave L
Gustav22
Hi Dave L,
I like your drawing.
I did a similar one here:
http://www.overunity.com/index.php/topic,1848.msg31317.html#msg31317
Maybe it means something to you.
I marked the double leads of the 6" and 4" collector in blue and red.
It might be worthwhile to calculate the frequencies - or rather the harmonic relationships - involved, based on the info given in your previous postings.
Unfortunately my understanding of the matter is not precise enough to attempt this, yet.
money for rope
libra_spirit
I do not read this launguage but the diagram shows the same relationship.
You have it right also!
So I am playing catch up then.
I was rather excited when I realized that the energy form flowing between the CC coils is very probably the same tempic field energy we have been exploring over on the c_s_s_p site. Many of us can sense this energy directly from special lengths of wound copper sine coils and scalar coils. In the tube device we can map the angles quite accurately and also feel the electric tingles between copper and aluminum tubes held along these angles.
Now I see someone else has already been exploring the hyetrodyning principle also, have finally caught up on that thread also.
But they seem to have missed the platonic angle application and the way torsion flows along specific angles, as well as the application of the phi ratio to make each layer a smaller size.
I am in the process of assembling parts for a TPU replication as well, so I can start to have first hand experience to see for myself how this all fits together when flowing electricity.
Dave L
Quote from: Gustav22 on December 22, 2007, 01:04:05 AM
Hi Dave L,
Jeff B
This ties together So many pieces of information, on this & many other threads.
Also, as many people will say - Pictures tell so much.
People are either Visual learners, or textual learners. In respect of speed, I fall mostly in the former category.
Everything drops into place fast.
Great work.
Eagerly awaiting results of your build....
ronotte
Hi Libra_Spirit,
even if some of the conclusions (about the 44mm distance) had been already well analyzed by Gustav some time ago, your work trying to apply Platonic solids geometry to ECD is very good. I've read almost all the work in the matter written by R. Hoagland and the derived hyperdimensional geometry: it's a reality that we have to face with. Actually you can check it just looking where are the planet's hot-spots so you will find that at 19.5 degrees there is always something unusual in every solar system planet.
About the ECD input freqs: well I've tried almost all possible direct harmonic relationchip and found basically that best of all are just what well known. Anyway remember that for itself ECD IS AN INTRINSIC WIDE-BAND DEVICE this to say that you will have an output almost for every combination!  The true work is to zero-in within few Hz on certain sweets spots...(profi equipment to do this...) they are really difficult to locate as when you tune-in you will have to fight also against a time-shift by-effect: it does mean that if you don't tune very slowly your oscillator...then you are going to miss the sweet spot!
Another issue is to make use of CHORDs: OK I never did it as I confess my ignorance but truly this is another way to excite the ECD and perhaps obtain better results.
Current synked issue: Yes is true I often used not squarewaves but 30% duty-cycle: this certainly lessen the current requirement.
One last thing: the ECD is a very good test-bench to gain knowledge into this class of devices but don't forget that the research is not into usig it as a 'transformer' but rather to convert RE spikes into pure sinusoidal waveform of amplitude & power sufficent to drive a load.  I succeeded only partially in doing this....now I think to know why so I need time to prove it.
Good work to all and if I could be of any help just write.
Roberto
