Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
Jeff B
For people (like me) not acquainted with NMR (Nuclear Magnetic Resonance), here is a good start:
http://en.wikipedia.org/wiki/Nuclear_magnetic_resonance
For an excellent "Beginners Guide to", go here: (A very well written introduction to NMR Spectroscopy. Lots of animations.)
http://www.cem.msu.edu/~reusch/VirtualText/Spectrpy/nmr/nmr1.htm
The second link in particular, is really helpful for understanding the whole field, even though it's bias is the Spectroscopy field
Just sheds light on everything, without extreme Brain-Strain.   ::)
Jeff.
libra_spirit
Yes,
NMR
The part missing from the NMR theory is where the atoms mass actually lies. The electron shell magnetic field is very light and can turn at microwave rates in copper, and the Proton and Neutron shells have the major weight of the atom. As you look at NMR remember where the force of mass is and now see what it is really doing, leisurely lagging the B field turns on the electron shell and spinning around before it stablizes.
Nisham Harrimen has now shown the phiscists that the missing energy in the universe is spin, not dark matter. Inside the copper atoms the mass is floating inside the electron shell, the nucleus some 1000 times heavier then the electrons shell and it is spinning. The hidden force of OU is tapping into this spin and using it. The spin is self recovering and never stops. But it always seeks realignment where the proton is spinning in reverse of one of the electrons dual spin components, and these normally cancel.
Tilting the electron magnetic field faster then the NMR rate seperates the two opposing spin forces and torsion comes up and outwards.
The limiting speed for the nucleus to turn its magnetic axis is the NMR rate, usually around 5Mhz in copper but increases with the magnetic field strength.
Any pulses with a faster rise time will seperate the two spinning fields instantly and we get the spikes. As the mass finally turns it creates the current. The current lags the voltage because of this delayed turn of the mass spin force at the nucleus.
This is why copper only responds to a changing magnetic field and not a statc magnetic field. If the diamagnetic response was happening at the electron shell there would be no delay of the reversed or back EMF, and a magnet would be repelled from copper in a stationary field. Forwards and back EMF are a reflection of which field is aligned with the wires linear length and how far the two are seperated in phase angle. Electronics as we know it is the result of the mass of the nucleus lagging the speed of the electrons shell turns. This creates the sloppy mess we call EM resonance.
Platonic resonance:
Platonic resonance is different because it is not locked into an EM frequency rate but spans many density bands. Look down the top of the hurricane photos and you may see a platonic form at the center. This is where the pressure waves start to line up between different velocity spin rates and connect across different pressure zones. This is the path torsion fields propagate. They can jump energy between two layers operating at different frequencies but only at the node points.
Sound will travel at different velocity through different density metals, this creates a mess of propagation delays, but when you see a platonic form become stable you know that at the nodes the energy is connected and a pressure node is formed where all the mess of frequencies at different densities syncronizes.
Platonic resonance is the primary connecting force, the EM comes later and gets very complex from a frequency standpoint. Searching out the frequencies is intresting but as soon as the densiy gradient shifts all the frequencies rise also. Density follows a harmonic or phi type of curve on successive layers. In a system with a varible density, there is no way to set up resonant circuits that can adapt. The TPU with just copper shows this. UFO's show us the time differential between densities. When a density gradient forms from a strong tempic field or a pressure zone in EM fields, a time differential causes frequency to loose its connection. Only the platonic form can span this gap.
I would recommend not adding any iron or steel to this system as the iron is magnetic at the electron shell not the nucleus like copper is. This will just start to create scalar microwaves, very dangerous. Use the shield if you try this. Iron also has nearly no magnetic connection to its nuclear mass, it can turn on a dime electrically with little lag time. Any scalar resonance will create tempic field microwave nodes along the short lengths of wire, and it will probably not create a mass spin force. In a magnetic field iron is always just sucked into it, there is no diamagnetic respose like with copper where a repelling force meets the motion of the field.
Roller coasters are slowed to a stop using copper strips along the track, and strong magnets on the cars. The moving magnetic field finds no resistance as it passes over the steel tracks, when it hits the thick copper plates it meets its lagging force which is much stronger then the momentum of the entire car. This reverse nuclear mass spin comes up with enough force to stop the car.
At this point for science to still claim this force is comming from the electron shell is not accurate. What we have missed is where the mass is operating from.
Dave L
Quote from: Jeff B on December 23, 2007, 05:47:04 AM
Jeff.
otto
Schpankme
Quote from: otto on December 24, 2007, 04:40:13 AM
merry Christmas.
Otto
Electron Power Systems has discovered how to make plasma toroids, called EST's (Electron Spiral Toroid's) that remain stable in air with no magnetic fields for containment.
http://www.electronpowersystems.com/Technology.htm
- Schpankme
Megla
Otto from which country are you?
I saw multimeter on which write Iskra. Do you from Slovenia?
