Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
AhuraMazda
We are on page 86 of this Successful replication of the TPU.
By now there must be many who are impressing the family and friends with their near miraculous achievement.
I don't subscribe to the general view that TPU contains stacked layers of of round coils. My question is this:
why is the cross section of the SM's TPU oval? Or even near rectangular?
Something like Fig 5 of the enclosed patent.
AM
spacemonkeyjazz
hey guys I am new here.  I was wondering does it work? If so does it work without electrical input and no oscilloscopes etc....
It seemed that 6 months ago you had a break through was all of that wrong? or what happenned?
If someone could condense the last 86 pages in to one meaningful paragraph outlining success etc that would be great.
I would like to build one if it genuinely works......
Thank you in advance
Cheers Ben
z.monkey
Howdy Y'all,
I'm Mike.  I'm an EE and electronic product manufacturer.  I think what y'all have done here is outstanding.  But what I don't see is the power in / power out test.  You made the observation that the TPU was feeding back on the power supply.  What I saw on the power supply was positive current, feedback would be reduced positive or negative current on a DC power supply.  Now I DO NOT want to discourage you all, I think you are on the right track, and making a lot of progress.  I am willing to help design circuits that will help you.  I have been interested in this technology for over 20 years.  While I was not able to work out the generator itself, I was able to figure out a way to isolate the device from the power supply, so that real power in and power out measurements can be taken.  Also, because of the last item, we can figure out the power gain, and measure the relative efficiency of the device.
Rather than feeding back charging current directly to the power source in a reverse direction, I suggest using a more linear design.  Make the primary power source a battery, this way there is a fixed, limited source.  Add diode isolation between the battery and the TPU with a zener spike diverter to quash any high frequency, high voltage pulses moving toward the battery. Also a BIG cap helps to suck up power fluctuations headed back toward the battery.  This way you can get a handle on how much power is going into the system.  You should have a volt meter / amp meter combination or a power meter between the battery and the feedback filter, then the battery.
Next, you need a volt meter / amp meter combination or power meter between the TPU and the load which will give you power out.  Then, to recharge to the source battery have a power converter connected in parallel to the load.  This power converter should be something more efficient than a linear regulator, like a bucking converter.  Make sure to use a LC filter on the output of the converter to prevent the bucking converter switching frequencies from interfering with the TPU.  The output voltage of the battery charging power converter should be whatever the charging voltage of the battery is so you can trickle charge the battery and be able to supply a lot of current when you have a heavy load on the output of the device.
Theoretically an overunity device the provides the power gain and the supply current remains small relative to the output current.  I think this relationship is more linear.  As the current supplied to the load is increased the supply current from the battery also increases, and the need for a larger battery charging current increases.  However the supply current always should be relatively small compared to the load current, but not fixed.
What this project represents is possibly the most important thing that there is to work on at this time.  Being prepared when the fossil fuel runs out will alive a lot of suffering.  Then obviously there is going to be a market for these technologies after the fossil fuel runs out.  While it won't be as lucrative as fossil fuels or power line transmission industries, I feel that it will be more reliable, safer, cleaner, more cost effective, and more karmically sound than the present day alternatives.
Godspeed...
Goodwill to All, for All is One!
slapper
test - thanks for fixing this page :)
we are not alone :)
BugByte
This guy is selling plans to make a TPU for $39.00 USD
looks like the same as SM's TPU.
http://www.ncbookz.com/
http://www.youtube.com/watch?v=p1Eh-6hjBLY
