Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
0 Members and 153 Guests are viewing this topic.
Drossen
@Ergo
First off, if Steven Mark were a scam artist, he would be asking for money.  Steven Mark has not asked for money, the information he gave us, he gave without charge.  Second, there have been a number of people here who have had their TPUs output some impressive amounts of power.  Some of the TPUs people here have built had enough output power to fry their control circuits and even their oscilloscopes.  The technology is real.  If you are not going to help out the cause through experimenting with coils you build, then please go somewhere else.  Thank you.
Drossen
Failure is not an option (it comes bundled with Windows)
Ergo
I'm afraid your totaly wrong in this matter.
No TPU can ever work in overunity mode. It's simply impossible. You can give up trying. It just won't work.
Here's the reasons.
1) Just playing around with a toroid core and putting on different windings will never become overunity.
    Any kind of ferromagnetic core with a winding, no matter how they are wound, is simply being a regular coil or transformer.
    It doesn't matter if the winding is "mysteriously wound" or someother crazy explanation. It stays being a transformer.
2) Inserting a permanent magnet into the toroid will just shift the ferromagnetic B/H curve from Zero to the same level as the magnetic flux has induced.
    Trying to "harvest" the flux from the magnet is not possible because it takes the same amount of energy going into the transformer as
    the magnet has shifted the B/H working curve by its static flux. This is why no magnet inserted into a transformer is able to "boost" it.
    The permanent magnet will just detorioate the ferromagnetic properties of the core and lower the efficiency. This is no joke but pure facts.
3) The only way to build a TPU would be if there existed permanent magnets that could be shut On/Off requiring no energy.
    But this type of magnets does not exist, nor will it ever exist, and therefore will a TPU never exist. This is simple physical facts.
/Ergo - Well educated.
Quote from: Drossen on March 05, 2008, 08:54:55 AM
@Ergo
Drossen
z.monkey
The TPU only deals with electron energy.
Therefore only the rules of electron energy
apply.  To get a OU/FE reaction you have
to tap another source of energy using the
electron energy, such as soft particles.
That requires a very different core, one that
has organic matter in it.
Goodwill to All, for All is One!
Drossen
@Ergo
Steven Mark never said his TPUs were overunity.  I never said they were overunity.  The power has to come from somewhere.  Steven Mark was not completely certain where the extra power comes from, but thinks it comes from the Earth's magnetic field.  However, there are other possible sources where the TPU may be drawing power from.  We know that the TPU will not work upside down, which suggests that the power drawn into the TPU has a certain polarization or direction of flow in relation to the earth.  The power may even come from the magnetosphere, or from charged ions in the air, or even from the large amounts of radiation coming from space that the earth is constantly being bombarded with.  No matter how the TPU collects the power, or where it collects it from, it does have more power out than what we originally put in.  Also, Steven Mark did not use a "ferromagnetic core", or any other metal core.  One of the smaller units used a plastic spool.  The larger one used cork or wood.  No metal core.  Also, Steven Mark said that the permanent magnet is not necessarily needed in the TPU.  One interesting thing abut magnets is that, when electricity is passed through it, the electricity will flow easier in one direction than it will the other, causing a magnet to act as a weak diode.  In one of the units, the magnet receptor looked like two wire connectors that the magnet was placed on, so perhaps he was just using a magnet as a diode.  So without the magnet, the control circuit would be open, so the unit will not operate, but when the magnet is placed on the two wire connectors, the circuit is closed, and electricity can begin to flow.  Based on what you wrote in your last post, it is aperant that you are ignorant of how the TPU is made and how it works.  Before you start attacking the validity of the TPU, you should first read all of the main threads so that you will not be ignorant about the TPU.  You will find some interesting results from experiments performed by various people in this forum which does defy conventional knowledge.
Drossen
Ergo
Everything you just stated is just hearsaying and technological mumbo jumbo without any evidence what so ever.
There has never been any existing TPU that has been examined and proven to output energy from "space".
Not one single device. When you say there is working devices you simply repeat what you have heard. That's just rumors.
And it doesn't count. As long as there is no real working unit to be measured in a real lab every word you hear is just snake oil.
Face it. There have never been any existing TPU that's been proven for real. NONE..... And youtube videos doesn't count.
