Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
pauldude000
Quote from: otto on April 01, 2008, 03:53:39 AM
Hello all,
@Paul
500kHz is a low frequeny  (I tried this). We need a higher frequency. In the low MHz range.
Otto
;D is 4.12 Mhz better? I can't believe I managed to kick a 555 into doing it, But I have officially overclocked the heck out of one! I took some pics to prove it. (Have you ever used a laptop webcam to take pics? Serious keaster pain.)
First pic is the breadboarded 555 circuit. Basically the transistor/2diode circuit posted earlier. However, I changed some component values.
Second pic is a frequency reading.
Third pic is where I managed to tweak a few more khz out.
The Final pic is the waveform at 4.121 Mhz on my scope at 50ns 1v/div.
For square wave, it is terrible. For pulsed frequency, I guess it would work.
Paul
Finding truth can be compared to panning for gold. It generally entails sifting a huge amount of material for each nugget found. Then checking each nugget found for valuable metal or fool's gold.
otto
Hello all,
@Paul
its OK. Dont worry about the signals, they are OK but why is everybody building square wave oscillators  when we need SINE WAVES???
DFRO said to use 1 to 4 sets of pulses,  "packets" of pulses or "trains" of pulses or......just look at Stanley Meyer. In such a case of pulsing our coils we have a few pulses pushing our particles and then follows a stop - break and again we have pulses.......in such a case our MOSFETs are not all the time ON and this means that they are not sooo hot....
Then DFRO said to use a 9V battery for the power supply and RISE this voltage with diodes and caps...
Otto
Feynman
@otto
Square waves have sharp gradients (in Bearden's theory this may be important).   Also you can convert a square wave to a sine wave with a 6-pole analog low pass filter.
@pauldude
Nice overclock of the 555!
altium
Dear sirs, Giantkiller and Otto, would share a MHz range working diagram with me?
pauldude000
@feynman, & all interested in 555 circuits...
Do not get me wrong, but I am using a TS555CN (CMOS. ST datasheet 2.7 Mhz Max Astable Frequency.). I will try the circuit to see results on an NE555 or LM555 in this config later.
For those wanting to experiment with overclocking, I have managed to eek out 4.9mhz maximum now. I have some specs.
ACTUAL resistances:
4.12 above: fixed resistor 694 Ohms (690ohm rated metal film); variable 50k trimmer pot.
4.9 max: fixed resistor 248 (as rated metal film) Ohm; same 50K variable trimmer.
Timing Capacitance (AS Rated as my LC tester will not test accurately below 10pf):
2.7pf ceramic (ceramic is what I have right now, for those puritans :) )
Diodes:
1n4001 (i think) small signal switching
Transistor:
2N4401 NPN General purpose switching
555 timer IC:
ST electronics TS555CN, comparable to the LM555C
Have fun!
Paul
