Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
0 Members and 43 Guests are viewing this topic.
Bruce_TPU
@ Stefan
Otto said the heat sink ONLY was hot, but NOT the MOSFET.  He and Roberto were amazed by this, because where the Mosfet was seated was only warm to the touch, but the "exposed" aluminum was very hot, giving off electrons.
Cheers,
Bruce
steve_whiss
OK, I have read most of the Steve Mark thread with the links to the video (early 2006).
I don't recall ever hearing him talk about hard fast switching edges; rather about a rotating magnetic field (typically using at least 3 poles to roll a field about). Traditionally, that is done using AC - though he might have been hiding some info.
I had also read his patent - which is using 6 poles to roll a field about <just checked - got it in front right now - yep, Fig.1 of US 2002/0125774 A1 has 6 poles>
And. Have read a book by Tom Bearden (Free Energy Generation) in which he discusses a circuit working by creating a deep magnetic field as hard and as fast as possible - for a short time - and gathering excess energy on the rebound.
Seems to me that - the replication is working more like TB's design then SM's.
OK, so - that is good, but now I am confused. How does this thing work???
Perhaps it is a hybrid - I have seen mention of a "turbine" effect on one of the other threads. That makes sense - a peak being driven about the coil.
*** Q: does it matter if the effect is understood before patenting it / certifying that the effect discussed is like Steve Marks?
*** This is important if it wants to be given away - if someone else can say "Aha! That is not how it works - our wonder patent (2% better) operates in a DIFFERENT manner thus not covered.....
:( now getting xconfused.
Steve
Bruce_TPU
@ Steve
This WILL NOT BE PATENTED.  Open Source my friend.  I too think it might be a type of Hybrid.  BUT it has the main things that SM said.  "circuit potential(mobius) Short pieces of wire (control coils) and three frequencies".
I too believe STRONGLY that down the road of "efficiency" we will find some how, AC at 7.23 HZ in the control wires, but we will see.  :)  I am replicating and then experiment with several ideas.  As will everyone else.  This is why it is so important to have as many replicators as possible.  Experiment and then post result, and we all build on that knowledge!
Cheers,
Bruce
Merkhava
HI All,
I see a few replication pics and 3D visuals showing the Mobius coils taped to the outside of the support tubing.
Why not use 1/4" PFA tubing and run the lamp wire inside the the PFA? Then you can wind your control coils directly onto the PFA for closer coupling. That is how I'm constructing my version.
(I'm also considering another way - just cutting multiple stands of thin gage enameled copper wire equal length and running them through thin walled air tubing. Solder the tips on the ends to make my own version of Litz wire. I would make two 4" and two 6" versions, then connect them Mobius style and wrap control coil over the 6" tubes.)
I intend to build my PWM circuits without using a board.... All short lead hook and solder. My PWM network will be a small little ball of mess, being very tight and very little distance through which my charges need to physically displace. The control network will sit inside the center - hopefully safe inside the eye of the hurricane.
Robby
hartiberlin
Quote from: btentzer on June 13, 2007, 07:23:59 PM
@ Stefan
Cheers,
Bruce
Bruce,
when we look at the IRF 840 datasheet:
http://www.datasheet4u.com/download.php?id=284087
we can see that the outer case tab is connected to the drain.
So if the aluminium heatsink is heated via eddy currents and this will
release free electrons, do you think these will go additionally
into the circuit and will power the bulb ?
Roberto and Otto, did you have a physical connection of the case tab
of the MOSFET with the aluminium heatsink or did you use isolated glimmer
pieces, so there was no connection ?
If there was a connection and the free electrons from the
aluminiumheat sink would be sucked into the circuit,
then the heatsink would have itsself to be charged up positively,right ?
So does it do this ?
