Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
steve_whiss
Hi z_p_e,
..if wrong patent then I need backtrack my sources. Will chase this one tomorrow. Coming up to 2:45 am here; time for zzzZZZzzz
Steve
z_p_e
The patent numbers and assignee names have never been released, so good luck.
You'll find a couple of audio patents if you search hard enough, but that's all. We've been through this drill a few times already.
Darren
Mannix
I will clear something up.
The alu gets hot because of the intense magnetic field. just like an old car speedo/power meter.EDDY currents!. The reason that the heatsink was hotter was because the source of the heat was the aluminum. It is NOT desirable...in fact it offers nothing to the process. Interesting all the same.
There is much to discover without getting confused about what is known.
Nobody knows exactly how the tpu works...the question is. WILL WE FIND OUT?...then HOW? ..by experimenting!!!!
Some of you may be content to really know THAT it works.
You are going to blow up a fet or two .....be prepared to do so.
See the diversions increase??
Lindsay
Bruce_TPU
@ Bob.
I was quoting Otto and HIS belief that the aluminum is giving off electrons.  Aluminum when heated does give off electrons.  Otto also stated, that it will not work, or not work as well without the aluminum in the center.  I know that tubes are in a vacuum....LOL but again, this is NEW TECH and SM has created a type of ion generator, except from what SM tells us, these electrons are traveling at the speed of light and not "ON" the wires as electrons usually are...LOL  Thus the "Reaction" in the Reactor/TPU as they SLAM into air molecules, producing more electrons, and so on as you have the avalanche or cascade effect.  All of what I am saying is from what SM states in his posts, and what Otto has said about the aluminum.
Cheers,
Bruce
Bruce_TPU
@ Lindsay
When can we expect to see pictures of your replication efforts?  :)
Your comment on the aluminum is based on??  SM? Experimentation? Intuition?
I was simply quoting Otto and his thinking about the aluminum, for he feel VERY convinced that it is important.  Now, if you say SM thinks it is unimportant, that will mean something, and we need to know it is from him.
Cheers,
Bruce
