Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
hartiberlin
P.S.he is still fiddling with the connection setup.
Not yet fired it up...
TheOne
Ok now i see one frame par 20sec approx
if you activate the FPS view that completely stop the camera to work
Mannix
Quote from: btentzer on June 13, 2007, 10:11:03 PM
@ Lindsay
When can we expect to see pictures of your replication efforts?  :)
Your comment on the aluminum is based on??  SM? Experimentation? Intuition?
I was simply quoting Otto and his thinking about the aluminum, for he feel VERY convinced that it is important.  Now, if you say SM thinks it is unimportant, that will mean something, and we need to know it is from him.
Cheers,
Bruce
It aint personal Bruce.
I thought that I had already mentioned the alum problem.
We are all learning things...Its is a well known feature of alliminium I rarely say specifics unless the source is good...I dont refer to it any more .....No questions on this.
My efforts are with tubes...
Everytime I use mosfets I blow them up...
Pictures? When I think that they will be seen as to contribute to the wonderfull efforts of others..
all,
UEC meeting is arranged.
Better get some more replications up guys!
The more success...the more info will come...But perhaps not as soon as I would like.
BTW if any body wants to send something important to UEC,
PM the text in the next few days and I will pass it on, in person, when I get the opportunity.
Lindsay
Bruce_TPU
@ Lindsay
I understand, that was all I needed to know.  :)
I am going to think on some questions for the UEC and then PM them to you.  If you like them and think they will help us here, please share them.
Thank you,
Bruce
hartiberlin
Hi Lindsay,
good to hear, that you are now in contact with UEC.
Please just ask them the most logical questions:
1. What they want to do with the technology ?
2. Is there anything we can help to get this technology out to the people and not getting further suppressed ?
3. Maybe they can come forward and tell us the whole story in detail.
4. Do the old TPU prototypes from Steven Mark still exist und who is using them right now ?
5. Do they want to go commercial and do they look for manufacturing partners ?
6. Is there any governmental involvment to suppress this technology ?
7. When can I buy a TPU ?? ;D ;D ;D
Many thanks.
Regards,Stefan.
