Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
0 Members and 18 Guests are viewing this topic.
Earl
@ IST
Looks like you had much fun winding the toroid.
There are some things that confuse me:
1) You have about 8 turns of wire on a (plastic-cored ?) toroid that is being excited by a 120 Hz half-wave rectified sine of normal 115 VAC signal.  OK it will not be very close to a sine wave, more a distorted approximation since inexpensive inverters never are true sine wave output.
I would think this winding would present a quasi short-circuit to the output of the cigarette lighter inverter.  Do you not blow fuses or smoke the inverter ???
Something looks very fishy to me.
2)  I see nothing that should cause any field to rotate.  It looks like a simple transformer, nothing more.
And if the core is plastic, the coupling between windings would not be all that high, so even transformer action would be lower than optimum.
3)  What does this toroid do that would be interesting ?  It seems to be a very banal and boring design.  Lighting up light bulbs while discharging a battery makes me fall asleep.
To be interesting it has to light bulbs while charging a battery and must be able to be replicated by several peers.
Earl
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
giantkiller
I thought pvc at first. But i believe it is painted steel.
sfieszaq
Hi Otto,
Please if You could give me your favour.
Could You modify your TPU (only MOS FETs adding a diode as I shown on diagram) and check if You can get any conversion.
Adding this diodes we eliminate effect of internal diode. I think it can be the key.
Thx in advance
Sfieszaq
otto
Hello all,
@sfieszaq
I hope I worte it right
There is no need for the diode.
Otto
sfieszaq
Hi Otto,
I want just to say, that the internal diode seems like work for us. Otto, please just do this test and check if You can get any conversion. You can use MOS FETs or Tubes but the biggest different between them is this internal diode in FET transistor. Just see how different works your TPU.
S-Q
