Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
chrisC
@mannix
For those of us who are unfamilar with UEC (including myself), can you tell us if the control circuitry patent is assigned to UEC. If so what is the patent number and where was it filed & granted.
Also what is this UEC meeting going to be about?
chrisC
c0mster
Wow , I didn?t expect such a large audience, I set my cam limit to 10 connections and it was full the whole time?.. I hope some of you where there when the 40 watt 120v globe lit a little. I hit around 40khz and when I touched the bulb it was hot, I tuned a little more and it started to glow. I need to tweak my driver so I can adjust the frequencies better. As well the darlinton pair puts out way to many amps so I need to resist the base. Thanks for the offer for the ftp, sorry the frame rate was slow , I?m on dsl and I am limited to 60k upload speed. I hope to do some more tweaking in the days to come but don?t know when I will be on. Just check the cam page every now and then and you might catch me. I set it as my home page here.  Once I have things tuned and the light is at what appears to be full brightness I will post a time and do a live demo to calculate the actual wattages.
Thanks folks
Cam
hartiberlin
Hi Cam,
many thanks for running this demo.
I hope you can work out the last bugs from your circuit.
Did you already see any superimposing waveforms like Jason posted ?
Yes, I could see the bulb barely glowing, but how much power was going into
the system then ?
Did you see any strange waveforms at all with your setup ?
Many thanks.
Bruce_TPU
Hi Cam,
I would suggest using the same two frequencies that Jason found, 90 KHz and its Harmonic of 180 KHz.  If that works as well for you, as it did him, and you are feeling safe, try the third frequency of 270 KHz.  This is the intermodulation/sum of the two as your third frequency.
Lastly, I would suggest an aluminum screen between your TPU and equipment and your body.  ;)  Jason has it right.
Good job,
Bruce
passion1
Otto/Ronette and other
Conratulations!! I am fascinated by what you have achieved!
I would like to start building a replication myself but is a bit concerned about all the warnings of danger. Could anyone please provide a short list of the critical safety measures (e.g. an aluminium screen etc.) that should be in place to protect a novice like myself from making any unnecessary accidents.
Thanks in advance!
Passion1
