Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
havuhung
Hello All,
@Operator
If the research work on using TPU without the vacuum tube or transistor or FET such as Transistors; no electronic circuits will enable the initial TPU can never work. In the Videoclips and photos from SM-TPU electronic circuits manufacturers have been hiding, I think so. . .
If a direction that the work of the TPU is used under principles of nuclear magnetic resonance, or in some way similar probably will again become more difficult reality.
samedsoft
Dear Otto,
  Can you make an updated document how to replicate your work step by step with all circuit details.
  So that we focus on a standard project and then discuss further about bigger versions?
  Thanks for your help to humanity!
ПВА
РебяÑ,а все рабоÑ,аеÑ,!!!!! Ð'нимаÑ,ельно прочиÑ,ав всÑ' чÑ,о сдесь написаноhttp://selftrans.narod.ru/v3_1/brus/brus72/brus72.html,и немного подумав как эÑ,о можна соедеиÑ,ÑŒ в единое целое, вы получиÑ,е Ñ,о чÑ,о Ñ...очеÑ,е.А генираÑ,ор я сейчас вам скину,но Ñ,олько над ним Ñ,оже надо порабоÑ,аÑ,ÑŒ,Ñ...оÑ,я он и рабоÑ,аеÑ,!!!!!!
Operator
Quote from: ПÐ'А on February 14, 2010, 05:05:24 AM
Ð'о-первыÑ..., давай по-английски!!! Не можешь - до свидания. Уважай Ñ,,орум!
Ð'о-вÑ,орыÑ..., уÑ,верждения "все рабоÑ,аеÑ," никого не инÑ,ересуюÑ,, поскольку здесь иÑ... миллиард. У всеÑ... все рабоÑ,аеÑ,, давно. Если у Ñ,ебя чÑ,о-Ñ,о имееÑ,ся, Ñ,о Ñ,,оÑ,ки и видео в сÑ,удию, если неÑ, - до свидания.
Translation for those who does not speak russian:
Guys!!! Everything works fine!!!!! After reading http://selftrans.narod.ru/v3_1/brus/brus72/brus72.html and a bit of thinking of how to put it all together you can finally get what you want. This is a schema of a working generator which needs some improvements nevertheless.
In my own opinion it is yet another piece of crap. I suggested him to show us a working device first.
ПВА
ПодождиÑ,е немного!!!!Ð'се дудеÑ, сняÑ,о и показано,в Ñ...орошем качесÑ,ве,и самое главное.Ð"аже последоваÑ,ельносÑ,ÑŒ сборки,но Ñ,олько извениÑ,е но на руском,поскольку ангсийским не владею!!!!
