Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
0 Members and 18 Guests are viewing this topic.
kabetov
Good day everybody!
I'am very interested in this gadget. I want to order one with next parametres: 220 volt, 40 watt.
I'am live in Moscow, it's so dangerous days come, so i need some help.
Best Regards, Artyom Kabetov
kabetov@svetobor.org
Operator
Quote from: kabetov on March 08, 2010, 01:57:59 PM
No one knows how to build such a device yet. That's why we are here. Be aware of a scam.
Rus: Пока никÑ,о не знаеÑ,, как собраÑ,ÑŒ Ñ,акое усÑ,ройсÑ,во. Именно поэÑ,ому сущесÑ,вуеÑ, эÑ,оÑ, Ñ,,орум. ОсÑ,ерегайся мошенников.
the_big_m_in_ok
Quote from: wings on March 09, 2009, 03:57:20 AM
this one ?:
http://magnetism.otc.co.nz/Sweet.htm
@all
otto said in Reply #1446 that the address above was good.
Sorry I get an error page on it and    http://www.magnetism.fateback.com/Sweet.htm   was the same way as well.
--Lee
sfieszaq
Hi,
Sorry maybe someone had this idea already... TPU vibrating ~5kHz:
Speed of sound (copper), 3570 m/s; 3570/5000 = 0.714 m = 71.4cm;
2*pi*r = 71.4cm; r= 11.36cm; d = 2*r = 22.72cm/2.54 ~ 9" but it is full resonance. TPU does not work in full resonance.
My idea is. 3,4 or 8 (>=3) control coils. A copper collector. uP with proper firmware and generator connected to uP's CLK_IN.
A few examples for 4 coils:
       ex.1            ex.2
coil 1  10001000   11001100
coil 2  01000100   01100110
coil 3  00100010   00110011
coil 4  00010001   10011001
I am going on my hols soon but after I would like to check this idea :)
Watch on Youtube this movie. Maybe similar ocurres with electrons(?) in collector:
http://www.youtube.com/watch?v=PQ-NvQ-z3K0&feature=related
to Otto:
when your TPU is tunned check gaps between pulses and try to count distance for copper. In gaps your magnetic field is moving free across collector. When you have pulses You changing speed.
S.
andrea76
Quote from: giantkiller on March 01, 2010, 10:41:30 AM
Two things:
The ring configuration is in the vein of the ECD and the scope shot shows major promise. The ringing shows up symmetrically in the on time. But the off time has a higher peak to peak and faster oscillations. This is most important! The self oscillation start is in the off time. His scope shots show the same pattern I started with. The next test is to reduce the on time or change the on time to 25%. His signals are 75%/25%. You want the off time oscillations to overlap the back end of the on time ringing. In other words 'The two sets of waves will overlap'. ;) Then you see the consecutive spikes building. We push the swing at the correct time...
The constant DC at the back end of the on time stabilizes the polarity of the electron torque. All is quiet. This stops the oscillatory function. Then the off transistion has to start up again only to lose any reverberation that might happen. The reverb or echo is necessary to start an acoustic or wave tidal imposition. This whole process uses the established wave content or standing wave as a bias or stored energy. That is the constant resource that resonance supplies.
Here is what I have seen: The coil produces intense noise in the off time. If the duty cycle is lowered the next check is to see where the off time oscillatory function stops along the off time window. If it stops short of the impending on time occurance then 2 things have to occur. Change the input frequency or the coil winding/configuration. Sm stated he 'snipped wires'. This can happen in alot of ways and do alot of things.
Now the unfortunate news:
This is the feedback process that is like a teseract in a house of mirrors. You change one parameter then go to another part of the configuration and adjust something else. It could be electrical or mechanical. That is the nature of the beast. I got to this point and the next step is to work the power output stage. In other words: Once you have established the echo you then need a target. Whoa!
Previous efforts have attempted to drive a coil to get power. This is basic transformer action and will not work. Doesn't matter if you use square, sine, or spark gaps. Just because you step on the gas doesn't mean you'll make it around the corner faster. >:(
http://amasci.com/freenrg/a-vectFE.html
http://amasci.com/tesla/tesceive.html
the tpu converting the gravity into electrical energy trough the electromagnetic fields.it is similar to hendershot and hubbard.the earliest hendershot unit working only when it's put on the n/s direction(for collecting the earth electromagnetic field,like testatika ).the key is in the correct interaction from 2 frequencies! see the work of dr. hooper( it's like to hubbard-the core likewise as a single winding )....
