Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
kokomoj0
Quote from: c0mster on June 14, 2007, 11:54:09 AM
I thought I just stated in my last post that true input and output wattage needs to be determined, we need to do this be it windows motor, that guy with the newman motor, or the SM device. Please be patient, myself and the others are working real hard to provide real evidence.
Kool!  i will have a cold one then and await your results  :)
Bruce_TPU
@ Com
Your control coils looked to be made from single strand magnetic wire.  Is this the case?  The replication calls for STRANDED.
Also 7 amps output from your P/S in wire rated at 2.2 amps....Hmm....and they did not melt and burn up...hmm....I wonder why!  LOL  Think about it! :)
And besides this, you used a different circuit then the one posted.  So this IS NOT a replication but your own ideas mixed with a properly wound coil.  PLEASE RE READ Roberto on the NEW FAQ THREAD and then build it EXACTLY TO SPECS and then post.
Keeping it honest,
Bruce   ;)
gn0stik
Quote from: kokomoj0 on June 14, 2007, 12:07:25 PM
Hey Koko, we're all in a quest for answers here. You seem very knowlegable and capable. Any help testing would be appreciated. It's not very hard to build, and doesn't take much time/money. At this point, I have to say, the position you have taken from the very start, and your contemptuous attitude is not very conducive to someone wanting to perform tests for you, while you mock us, and what we've done. As far as we know, we could go ahead and perform your tests, and you would not accept them anyway, as you probably view us as being biased. Perhaps the tests would be more believable to you, if you performed them for yourself? You after all would be the most logical to perform those tests, as you would no doubt be doing it from a different perspective, and could perhaps be more objective?
Ideally it would be good to just drop the device off at some highschool or college, and have them perform the tests, as they probably have not heard of the device and have formed no opinions whatsoever.
Perhaps, you could save everyone a whole bunch of time by quantifying, and qualifying output?
You would definitely satisfy a lot of curiosity, and would be doing the community a favor.
BTW I'm a brewer and kindof a beer snob. I don't think you wanna spend the kinda money it would take to buy me a case of my favorite beer.
Regards,
Rich
chrisC
Bruce:
As far as I know (I may be wrong), there is no electrical difference between the stranded and un-stranded magnet wire. Stranded wire is structurally better made and will not kink easily(?), for all intents and purposes they are the same, I think.
chrisC
gn0stik
Quote from: btentzer on June 14, 2007, 12:15:26 PM
@ Com
no, and wrong
Keeping it honest,
Bruce   ;)
I don't know what you were looking at, Bruce, but Cam's is almost identical to Jason's. Oh, and he HAS read it, and has built it very close to specs. The specs which you apparently MISREAD!
The reason I say "very close" instead of "exactly", is because we're not using european wire guagues, and there are some vaugeries that have yet to be addressed in the document. Can you point them out? Oh, and by the way, he did light a bulb.
Or can I ask how your replication is coming? If you want to critisize someone about their build and tell them to not post until they have built "exactly to specs"(all in caps) perhaps you should refrain from posting until you have built "exactly to specs", and tested? And perhaps you should go back and read it AGAIN! instead of skimming it, and calling that good enough. Reading comprehension is your friend.
This should be entertaining. Just keeping it honest you know.
;)  Rich
