Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
mrd10
Hi Bruce,
the bulb was a 40watt bulb , @ 120volts
Cam is converting video as we speak. we put a bridge across the load to see and it showed over 1000volts, this was HV,
Dom
Bruce_TPU
Can you say, "WOW!"
New energy source indeed ...
Bruce
tosky
@Bruce
The "seed-effect" may not be odd. Since Otto use 6V to drive the MOSFET very close to the threshold value of the MOSFET with the miller-effect from the D pin output, it is very easy to drop to under threshold value operating dynamically. That is the MOSFET work at the linear region just like a "class-A" amplifier. Work with the capacitor of the GATE of the MOSFET, it smooths some high frequency square wave to be like a sine wave at some pulse condition. To clarify this, Otto should use a good MOSFET driver such as IRF7307 and at least 12V to drive. The "seed" may be lost.
mrd10
d/l the movie in the first post on this page   8)
chrisC
