Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
0 Members and 138 Guests are viewing this topic.
Bruce_TPU
Hi all,
A fitting time for SM's words:
"Suppose you have 1,000 pieces of wire twelve inches long and you
run the same weak magnetic field over them all at the same time..... you get the same flow of electrons.
If the wires are run in series then you will get the 12,000 millivolts
etc.
If you connect the wires in parallel you will get higher current but
lower voltage.
However, the power potential is the same whether you run the
wires in series or parallel.
If you know how to find the circuit potential, you tune into the frequency and you have enough short pieces of wire you can
convert as much power as you wish in a given space."
AND
"It took several years of experimentation to discover what frequencies and most importantly how to make small integrated circuits work to perform the control functions necessary to make the demonstrations you see on the video tapes available today."
To conclude, this will not be a fast process.  I believe that there will be specific frequencies that will bring the power.  He showed 1000 V.  with the bobbins.  What if they were stranded and wired in parallel and not in series?  And AC changing magnetic field in the coils would also be a good experiment with three frequencies.  We need to be methodical in our experimentation.
Thank you for your time,
Bruce
Hoppy
Quote from: mrd10 on June 16, 2007, 05:28:20 AM
Hi Hoppy,
Cam was the one that was in the lab, i was just his assistant, and jotted things down as we went along. In video were using 12volts (battery), note also video was done after we did alot of testing. Do not stop testing your setups, add the 3rd freq and do more tests.
We just did this because this is the time we had and we did it.
Also this is a reference point for other builders that can verify what we did.
Sincerely,
Dom
Apologies for the mix up Dom.
Clive
Earl
Darren,
If you are only interested in a square wave, there are high-Amp FET drivers that have a Schmitt trigger on the input.  It could very well be that this Schmitt trigger will turn a sine wave into a nice square wave.
Of course, using a 74HC132 Quad 2-input NAND Schmitt Trigger following the DDS oscillator will produce a beautiful square wave with fast rise/fall times.  In this case solder the Schmitt trigger right next to the FET driver.
If you want variable-width pulses, follow the Schmitt trigger with a 74HC74 Dual D Flip-Flop, where the proper output pin goes to the reset pin.  If this pulse is too narrow, it can be widened with a series R, eventually series R followed by capacitor to ground.
In the next days and weeks, I will be posting lots of ideas and useful circuits.  I am real busy right now.
Regards, Earl
Quote from: z_p_e on June 15, 2007, 12:25:43 PM
Earl.
Thanks for the heads-up on the DDS oscillator.
Unfortunately it doesn't output squares or pulses.
I suppose it one could interface it with their own zero-cross detector, and generate squares and pulses from that.
Regards, Darren
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
Bruce_TPU
Hello all,
SM said:
I am using 6BQ7-A tubes for the input and phase inverter because they
are VHF amplifier triodes designed to operate in Color TV at very high
frequencies and so you can imagine how crystal clear my high frequencies
are in my stereo amplifier.
Now what is this phase inverter for the TPU, I asked myself.  And this is what I found:
"a circuit that generates two output signals, each 180 degrees out of phase with the other. This is a bit of a misnomer, since it does more than just invert the phase of a signal, it actually generates two out of phase signals."
Again, another important line of experimentation!
Cheers,
Bruce
z_p_e
Earl,
Thank you for the ideas. I look forward to your circuits to come.
Years ago I designed a very stable and sensitive LM311-based zero-crossing detector for a project I was working on, but I can not find my schematic.
Will this 74HC132 Schmitt Trigger do just as good or better job?
Thanks,
Darren
