Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
0 Members and 214 Guests are viewing this topic.
replicator
@Roberto
Please look at this link: http://jlnlabs.imars.com/spgen/index.htm
You can find several interesting thing at the bottom side of page, what is ghostly the same you can name "Seed" in your PDF. Is the two thing "Seed" and "Soliton wave" are identical? I know there is difference because Naudin uses ferrite rod, but I mean is the phenomenas identical? It could be help us if we know what we are looking for. Maybe a "Soliton wave" in Moebius loop?
@Dam
Just a tip: Could you measure the capacitance of Moebius loop and inductivity of CC secondary then tune into its calculated resonance's 3rd  subharmonic of your oscillator?
Regards,
Replicator
CTG Labs
Hi Replicator,
I cannot see how this is the same as the Soliton Pulses are created by a wave movement of the domain walls inside the ferrite which occurs after the pulse has turned off.  There is no magnetic material for this to happen in the TPU.
However if one frequency is a harmonic, will we not find one mosfet on at one point while all the others are off and this will produce only a small signal/spike while the others are off and it will appear inbetween the large signals.  Can we say for sure from the info in the PDF that this signal is unexplainable and appears out of the blue inbetween signals applied to the TPU?
D.
mrd10
Ok I re read Robertos post, so this is what we are looking for people:-
The seed, then we move this seed into the spike, and we should get that pulse peak, or as Roberto mentions sinoudal wave, and this is the conversion process were looking for, (referring to my previous post pic on page 39).
Hmm I'll see if Cam is willing to do more tests to see if we can nab this in the butt, I don't think we have an issue here, as long as we know what to look for now, and observe what happens, I'll be speaking to Cam soon about this.
Ok Roberto has confirmed below that this is the close up of the seed.
Kind Rgds,
Dom
ronotte
Hi all,
I apologize not having enough time ..... But YES WHAT POSTED IS THE SEED.
Look for that please.
Once you see it you are on the correct path...SEED is the key to open the 'DOOR'. nothing is more important...so don't give up searching until you see that event.
I don't know where it come from even if I already told you all I know about in TPU=ECD doc. If you go to pg. 52 you will see exactly the Seed waveform for Al case!...it's a rather complex wave ...but I've already written about, please read it.
One thing is clear: if you don't put aluminum or other heatsink metals in the nearing of the ring ...THE SEED DOES NOT APPEAR'  (first pic is for Al heatsink, second pic were taken bolting MOSFET to a Mg block...please see the Signature differencies!)
@Replicator
no Soliton waves are a different thing.
Good luck to all
I'll help as I can
Roberto
mrd10
Thanks Roberto, much appreciated.
Dominic     :D
