Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
c0mster
If you keep cooking your mosfets try the IRF730 they seem to perform well for me.
I will do some more test later in the week to verify the seed.
Cam
mrd10
Folks it just occurered to me, that SM used to talk about Vacuum tubes right, well how do they function, they produce heat, same thing what Otto and Roberto have found out,
what if this is what cancels the magnetic flux and speeds up our electrons, same as what happens ina vacuum tube.
what about the imploding tv set, if the coil malfunctioned or there was heat involved, which set things in motion, wow.........................
refer to the heat magnet motor, you bring heat next to iron, with magnetic field near it like a magnet, and what happens, it looses it magnetism, so im thinking along those lines:-http://scitoys.com/scitoys/scitoys/magnets/magnets.html
Also we know that these things produced heat, so there's the other clue.
Kind Rgds,
Dom
mrd10
Quote from: ronotte on June 18, 2007, 08:53:17 AM
@ Dom,
Here is a full labelled image for all. I hope it will be of help
Roberto
Thanks very much Roberto.
gn0stik
Quote from: z_p_e on June 18, 2007, 09:33:58 AM
In order to assist in defining what these "seeds" are, I've decided to simulate the circuit I posted.
If I can create these "seeds", I should be able to determine what they are, and what is causing them.
I will be striving only to re-create these waveforms, and will not be looking for or expecting overunity nor conversion processes nor anything of that nature. I also realize copper masses will not be accounted for here either.
I am asking anyone that has a control coil wound with the primary and secondary as per the document, and is able, please post your coil measurements.
- Primary and Secondary inductance and resistance.
OR
- coil length and diameter, and number of turns if possible, along with wire gauges.
It wouldn't hurt to compare everyone's coil specs anyway.
Thanks,
Darren
ZPE, I posted my control specs a little while back before Mannix told me that the spools were wrong, they are rewound now, but the gauges and primary length, as well as wire weight is all still the same.
Rich
z_p_e
Thanks Rich...got those.
Inductance is the most important measurement I need however, and failing that, I can calculate approximate inductance from the coil dimensions I mentioned.
Darren
